Results 1 to 25 of 25
Thread: Fuel primer
    Mar 2020
    23
    Fuel primer
    After two primer strokes, my primer becomes rock hard. Like a hydraulic lock!
    Anyone have and ideas of what may cause this? Blocked primer nozzles ?
    11,148
    Very possible. Disconnect the primer line from the nozzle and try again.
    20,822
    When was the last time the nozzles were cleaned. Hoppe's No. 9 Gun Cleaning Solvent works great. I would work my way through the system but that sounds like the likely culprit.
    May 2014
    Buena Vista, CO
    158
    A cheap ultrasonic cleaner with a touch of solvent works wonders on primer nozzles.
    Aug 2003
    1,380
    Quote Originally Posted by motosix View Post
    Motosix, what solvent do you use for this type of work? And slightly off topic, what would you use for wheel bearings and such in an ultrasonic cleaner?
    Thanks. cubscout
    Jan 2017
    Utah/Alaska
    286
    As said earlier. Hoppes #9, works in ultrasonic cleaners too.
    Likes Colorado-Cub liked this post
    55-PA18A's Avatar
    Dillingham, Alaska
    670
    Quote Originally Posted by redfin View Post
    Does the primer stay out and locked? Or eventually gets pushed in?
    Please let us know what you find was the problem. Hate it when someone asks for advice, gets responses, and we never hear anything more. We all learn a lot from these questions.
    Love the smell of Hoppes #9.
    Jim
    Thanks Mattpeed thanked for this post
    Likes Steve Pierce, Brandsman liked this post
    May 2014
    Buena Vista, CO
    158
    Quote Originally Posted by cubscout View Post
    Pretty much like everyone has already said:
    For nuts bolts metal parts that are just covered in grease or the like, a small amount of that purple power degreaser from WalMart in the ultasonic cleaner with the temp set on as-hot-as-it-will-go. Brass fittings clean up nicely this way too, although anything copper will have the shine knocked off using this method.
    For parts that have caked on carbon like the primer nozzle, I'll presoak in Hoppes and take a plastic dental pick to scrape off the big chunks, then do the above. The primer nozzles come out of the bath looking new.
    With almost no prep, varnished carb jets (and even the entire disassembled carb) come out of the ultrasonic cleaner looking like new as well.
    akavidflyer's Avatar
    Apr 2010
    Soldotna AK
    188
    Amazing what antifreeze in a crock pot will do to clean up parts as well.
    May 2014
    Buena Vista, CO
    158
    Quote Originally Posted by akavidflyer View Post
    That is an old school car mechanics trick...and it works!
    Likes akavidflyer liked this post
    May 2013
    Alberta Canada
    70
    Momma might not want her crockpot back��
    WindOnHisNose's Avatar
    Lino Lakes MN (MY18)
    4,496
    I have a similar question regarding another component of the fuel system...the fuel sumps. I sump my fuel before every flight, but once in awhile the valve sticks open and there is some dripping. Any suggestions on how to prevent this?
    Randy
    supercrow's Avatar
    Dec 2008
    500
    That's a tough one Doc. Often times something small is stuck under the O-ring and draining a little will flush it out. Other times it has to come out and be cleaned or replaced. I have four on my machine and I find myself replacing one or more every couple years. You can sometimes replace the O-ring but I don't bother as a rule. I have better results by just changing them.My 2 cents.
    Thanks WindOnHisNose thanked for this post
    On Patrol's Avatar
    Jun 2004
    Wentworth NH" The WAD" NH96
    3,333
    Quote Originally Posted by supercrow View Post
    That's a tough one Doc. Often times something small is stuck under the O-ring and draining a little will flush it out. Other times it has to come out and be cleaned or replaced. I have four on my machine and I find myself replacing one or more every couple years. You can sometimes replace the O-ring but I don't bother as a rule. I have better results by just changing them. My 2 cents.
    Winter time I am careful to sump when above freezing. If not leave them alone or run the chance of ripping the O Ring with Ice. This advice and lesson brought directly from the ramp at KMLT.
    J
    I forgot if you grab the drain and rotate it while pushing in slightly it clears some dirt..... Good Luck
    Life should not be a journey to the grave with the intention to arrive safely in a well preserved body but rather to slide in sideways, well used up proclaiming "WOW What a Ride"
    2,793
    If the drains like to stick open it might be time to flush the tank(s) and clear the outlet screen if present. Once crap gets in the tank the outlet screen and small quick drain holes may not let it all out.
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    568
    Depending on age this could be considered a good thing out of context.
    Likes WindOnHisNose, hman442 liked this post
    3,878
    Not if it's clogged.
    Likes Willie liked this post
    11,492
    Quote Originally Posted by On Patrol View Post
    J
    I know a fella who did that, filled the tanks on a Super Cub, launched out of Kotzebue, headed for Anchorage, in winter. Plane had sat a lot for a long time, and he hadn't sumped the tanks that winter, using the logic you explained. He started off on one tank and didn't switch to the other tank till the first tank was almost dry....duh.
    And, guess what? The other tank actually had a good bit of water--actually ice, in it. Frozen solid. Gas on top of it of course, and the tank was in fact full, just not all gas.
    Fortunately for him, he wasn't that far from a village and was able to get there before he ran out of gas in the other tank.
    Lessons: Even in winter, sump the tanks. If you cut an O-ring, get it replaced. I carry a spare sump drain and wrench to replace. But, I've sumped tanks many, many times in winter without damaging an O-ring.
    Second, always verify that fuel flows from BOTH tanks early in a cross country. You don't want to get half way in the middle of nowhere and find out one tank won't flow fuel.
    Thanks 1934A thanked for this post
    Likes BC12D-4-85, DENNY, WindOnHisNose liked this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    568
    I think your innuendo detector is broken
    Likes WindOnHisNose liked this post
    3,878
    Nope! lol
    Sep 2002
    Southern NH
    882
    That’s because you’re not old enough to know what he’s talking about!
    Likes wireweinie, Crash, Jr. liked this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    568
    Clogs?!?! Do you soak it in Hoppes to fix that as well?
    Likes mam90 liked this post
    Dec 2016
    Canyon, tx
    809
    Crash,
    Iím going to let you in on a little secret. That blue color in 100LL.....itís not lead. Next time you and the Mrs. get together, splash a little on your primer
    Thanks Crash, Jr. thanked for this post
    4,496
    ....oh, boy...this thread is drifting...splashing a little on one's primer is not medically advised
    Randy
    Likes KevinJ, wireweinie, Crash, Jr. liked this post
    Mar 2020
    23
    Sorry for slow response, been out flying and limited connectivity!
    primer stays locked out stiff!
    I removed all primer nozzles, soaked in diesel overnight and then used a small pin to clean holes. Reinstalled all works as per normal.
    thanks for the advice. I will ultrasonic clean, but have to wait until I return home.
    cheers RF.
    Thanks Steve Pierce, Willie thanked for this post
  1. koler-essex fuel primer
    By MT12 in forum Super Cub Sick Bay
    Last Post: 10-30-2015, 06:51 AM
  2. Replies: 5
    Last Post: 10-02-2012, 04:46 PM
  3. Fuel Primer Kohler/Essex
    By Frank T in forum Tips and Tricks
    Last Post: 12-01-2003, 09:27 PM
