Thanks Thanks:  0
Results 1 to 14 of 14
Thread: “New” C90-8F oil pressure issues
    Nov 2015
    14
    Just test flew my L18-C with my Dons Dream Machines overhauled C90-8F and had some interesting oil pressure issues. Started out high after run up and takeoff (right at red line) and then kept on tending lower....to the point that break in cruise 2275 rpm was about 23 Psi in the yellow and when I came in to land and pulled over it would come all the way back to low red line around 10psi. It was a warm afternoon in AZ...90°ish. Was hoping to put in a whole hour flight but came back after 20 minutes to make sure
    I didn’t have a oil leak. Oil temp was steady at around 190°. No oil leaks noticed after landing. Anyone seen this before. Hopefully just a faulty gauge after sitting around for 15 years.
ID:	55231   Click image for larger version.
    2,767
    I'd call the rebuilder and exchange info so far. What oil is in the engine?
    7,402
    Check the oil pressure relief valve for a speck of dirt or something on the needle or seat. Very common with new engines.
    Likes JP liked this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    534
    This might be better posted on the J3-cub.com forum as they have more people experienced with small Continentals on there. Don's Dream Machines is on that forum too so you might get some assistance from the builder of the engine.
    3,837
    Is it making metal?
    gntw's Avatar
    Mar 2005
    Ft. St. John BC Can.
    151
    Is it making metal?
    I have built a lot of engine and that is usually because of to much bearing clearance. Have seen 10 under crank with std bearings have that problem
    3,837
    I was thinking more of something to tight, keeping pressure high. If it peeled some metal out of that location, the pressure would drop.
    Nov 2015
    14
    Is it making metal?
    They checked the screen and no metal. Talked to Lee at Don’s dream machines and he thinks it’s fine and possible just cooling on the hot day as they usually only see 180° on a C90 on a J3 with the exposed cylinders. Headed back out to fly it again tomorrow and will check the baffles (they are new) and see how it goes on a cooler day. Hope to get a few more hours on it if everything looks ok. I guess low redline is normal on a warmed up C90 at idle.
    10,598
    Quote Originally Posted by gravytime View Post
    C90 is no different then C75- 0200. I have had C85, 2-C90 and a 0200 and never had pressure that low at cruise rpm even at 210f oil. Even on a C90 with over 2200 hrs. My C85 stroker at 210f on a 90f day still has over 40psi
    Likes gravytime, Hardtailjohn liked this post
    Nov 2015
    14
    Interesting, will have to see what they say tomorrow and if they ended up changing anything.
    2,767
    Here's the small engine Continental Ops Manual: https://www.manualslib.com/manual/19...-A-Series.html
    Note the recommended C90 oil pressure (30-60 p.s.i.) and oil temp range (75-225*F) and limits. At idle with hot oil 10 p.s.i. is the absolute minimum. That's when operating in above +40*F air and using 50W oil viscosity at normal operating temperature in cruise and after landing. Single and multigrade oils are accepted.
    I've had a C85-8, a C90-8F, and now a C85-12F Stroker (C90 equivalent). All had a new overhaul to new specs. In cruise on a Standard air temp day I'd see 35-40 pressure at 190-210F and never below 20-25 later at idle.
    What oil's in the engine? Is the oil temp and pressure gauge accurate? Test both.
    Likes wireweinie, Hardtailjohn liked this post
    10,598
    But.......I also know of high time engines that flew forever and never saw 30 psi even when cold
    2,767
    It should be possible to adapt a cylinder leak-down tester so it feeds the oil pressure gauge (?) calibrated air. Oil temp accuracy can generally be noted from placing the temp probe in boiling water. I'd make sure of that soon B4 blaming the engine or overhauler.
    I'm just an owner that keeps dollar bills rolled up like toilet paper when it comes to these matters.
    Hardtailjohn's Avatar
    Marion, MT
    853
    I'd quickly rig a second gauge/line. Check the fitting where it leaves the engine, maybe flush the galley out and try that. It's cheap and easy. Then I'd go from there. Did they run the engine after build up?
    You could check your gauge with a good regulator on an airline...not very scientific, but it'll probably tell you if it's obviously that gauge.
  1. Replies: 5
    Last Post: 06-08-2020, 11:57 AM
  2. Replies: 3
    Last Post: 02-01-2018, 11:40 AM
  3. Replies: 15
    Last Post: 11-30-2014, 10:16 PM
  4. GPS issues?
    By mike mcs repair in forum Cafe Supercub
    Last Post: 05-02-2010, 07:28 AM
