scottsville
HI,
I have been chasing a carb heat issue and carburetor (maybe) issue for a while. New Carburetor by the way. I installed a new carb and the Atlee hot rod exhaust. Ever since then I am getting engine roughness with the carb heat on. If you give it a burst of power at low rpm it stumbles pretty bad. Sometimes with out the carb heat on it will stumble at low rpms. Plus just doesn't sound really smooth sometimes. I have been chasing this with idle mixture with no luck. Bought the carb from avstar. Marvel Schebler just like what was on it. No luck getting them to call me back. Just wondering if anyone out there has had this problem and figured it out.
Thanks in advance for any help with this issue,
Thanks Scott
Thanks Scott
