180 seats
If you're talking about factory jump seats, yes.
You'll have to install nutplates in the aft door posts for them though,
as well as install some sort of seatbelt attach points.
I'd recommend the stock Cessna outboard tabs, as per BAS (Lakevue) instructions.
Cessna p/n 0711084-15 (LH) & 0711084-16 (RH).
My centerline belt attach is a (modified) Cessna p/n 0711083-1.
Factory jump seats use two attach points. One in the door post and one in the reinfocing structure aft of the post. The 2nd hole up is my front attach point. The black pad is a scuff protector and the attach hole is in the center of that. Easier to see in my plane than most.
