Results 1 to 10 of 10
Thread: Brake bleed fitting to Goodrich brake seals
    Oct 2020
    16
    Hi all
    Resurrecting the original brakes on my 1960 Pa18-95.
    The short hydraulic tube from the Goodrich brake expander to the bleeder 'T' fitting has a B nut with a seal/Oring(s) inside it. (at least that's what i found)
    Can't find a parts reference to this anywhere. Anyone have information, part number, and or source for this seal?
    Was thinking I could probably use an AN 6227 of the appropriate dash number but I'd prefer a proper reference.
    S
    7,374
    It is a short hunk of special rubber hose - not an O-ring. I have successfully made them with rubber sheet and punches. You might try Univair.
    That won't be your biggest problem - all those expander tubes are now over a half century old. Rubber was better then, but a half century is a long time. Keep Grove in mind for a cheaper alternative.
    Oct 2020
    16
    I hear you re Grove but trying to stay original as possible. These Goodrich units have been mostly stored away as the aircraft was on float. Of course that can be a problem, but they look to be in real good shape.
    11,074
    bob has the experience with these. Often times a seal such as this appears to be a flat square sided "special" seal. An "O" ring over time forms it's shape to match where it is placed. My thoughts are an "O" ring would do the job just fine.
    Oct 2020
    16
    I agree and I can be sure the Oring is resistant to 5606.
    I guess there must be a reference document somewhere.. Given the details available for other aspects of factor supplied components.
    Perhaps Piper intended to sell the entire bleeder assembly for in-service issues.
    11,074
    Quote Originally Posted by Scott 2020 View Post
    A commercial "O" ring which is made of BUNA N is compatible with the aircraft AN 6227 and the 5606 hydraulic fluid. In some applications it is called out as an acceptable substitute.
    7,374
    Even the proper part would cause a necking of the expander tube brass extension. Before you cheap out and stick an O ring in there, look for some soft rubber tube that is compatible with 5606. Or use Dot 5 - it eats nothing.
    let me look around - maybe I can send you a used one.
    Oct 2020
    16
    Hope I I didn't give the impression that money was a motivator. I posted because my preference is to find the proper part or at least reference documentation.
    DR-109's Avatar
    Feb 2010
    Spring Grove, IL
    31
    A brass compression sleeve and compression nut that you can find at your auto parts store will work fine.
    Oct 2020
    16
    I had considered the sae type compression sleave but there's no seat in either the fitting or the nut, so I believe it will seal but clearly not the correct part.
  1. Brake Bleeder Fitting
    By Monte in forum Tips and Tricks
    Last Post: 01-30-2013, 07:54 PM
  2. Wag/Piper J-3 Expander tube brake fitting?
    By djonesutah in forum Super Cub Sick Bay
    Last Post: 05-09-2010, 08:50 AM
  3. Goodrich brake shoe specs
    Last Post: 11-29-2004, 07:40 PM
