Results 1 to 7 of 7
Thread: Alaskan fowler flaps and inline engine thrust mounts
    Oct 2009
    Wanaka,NZ
    368
    Has anyone a combination of the above.What effect do the flaps have on the approach trim etc?
    Likes AkPA/18 liked this post
    20,644
    I installed the Thrustline mod and I still preferred two turns of nose down trim on landing. After installing the P STOL Flaps I do not need to touch the trim except to trim the load after I level off in cruise. Other Super Cubs I have installed the Thrustline mod on needed no trim from cruise to landing.
    Thanks ron thanked for this post
    Likes AkPA/18, sharp liked this post
    May 2006
    Wasilla,Ak
    521
    I have a stock wing and engine mount Cub with with P STOL flaps and also do not change trim from cruise to full flap deployment once the Cub has been trimmed for the load. The experimental Mackey slatted wing with SQ 2 ailerons I recently completed requires lots of trim as it slows and the flaps are deployed which is the main reason for electric trim on this aircraft to speed the trim changes needed.
    Oct 2009
    Wanaka,NZ
    368
    Further to my Query, with a full flap approach would you guys say the aircraft requires much more power ? Does this situation improve stability?
    20,644
    No more power, more stable, rock solid.
    Mar 2015
    311
    And flies slower, stalls slower, all around more stable/solid as Steve says.
    John
    Likes petey451 liked this post
    11,073
    Don't you have the long flaps on your Cub Ron? Those performance details sound a lot like the 110" flaps on my Cub. It would be interesting to hear from someone who has the long flaps and who has changed to the double slotted Keller Alaska flaps.
  1. Fowler flaps
    By The Kid in forum Modifications
    Last Post: 05-07-2020, 11:31 AM
  2. Fowler Flaps
    By ross d in forum Cafe Supercub
    Last Post: 08-04-2018, 08:55 AM
  3. Javron Inline thrust
    By sub3 in forum Experimental Cubs
    Last Post: 04-17-2016, 10:00 AM
  4. fowler flaps
    By redrooster in forum Modifications
    Last Post: 02-06-2007, 01:38 PM
