Page 1 of 2 12 LastLast
Results 1 to 40 of 64
Thread: Where to start removing weight
    Feb 2021
    19
    Hey folks, it's looking like I'll be the newest member of the super cub club here in a few days! Plane is a late 50's PA-18A model in decent shape with a lot of useful things having been done to it already, it's just a little bit of a beefcake for an O-320 at 1240 lbs. The owner before the last one added a lot to the panel - full six pack with vacuum system, think it was even IFR certified at one time. It also has the belly pod fuel pump still installed, though no pod. So, how do I go about getting the weight down? Especially important as I'll be adding back onto the weight with most likely a borer prop (maybe composite but open to opinions), big o' tires, etc. Seems that the ag version was a little heavier from the start with the hopper door and reinforcements, but it shouldn't have been this heavy. I'd like to keep the starter and electrical for sure.
    So, here are my ideas for where to pull weight out, I'd appreciate opinions on which are most worth doing.
    * Remove vacuum pump, attitude indicator, DG => Around 15 lbs
    * Remove the belly pod fuel pump system => 5lbs maybe
    * Lightweight starter, lightweight under-seat battery, rear baffle oil cooler => 20 - 30 lbs
    * Seats are really nice but seems heavy, maybe there's 5 lbs there
    That's optimistically around 50 pounds for not a ton of money, which gets me towards 1190 or so.
    Any ideas out there for further weight savings? It already has Univair sealed struts, so no dice on the airframes aluminum ones.
    don
    764
    The pilot!!
    Feb 2021
    19
    That's what I always say when I see weekender type cyclists spending 1000's to remove a few ounces from their bikes, while happily ignoring the pounds that would be free to loose if they just rode the thing more!
    Likes cubflier liked this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    491
    Sounds like you've got it pretty much nailed. The only things you could consider doing in addition is taking the springs out of the front seat back and using a fabric covering to save weight there. Front seat bottom you'll want to pull the springs and use a sheet metal seat pan for easier access to the underseat battery.
    Seat cushions can be heavy depending on how old they are and the materials used. Might look into Sport Aero seats as they are pretty light. Rear seat is another place to save some weight by going to something like the Atlee Safari seat.
    Honestly if you're under 1200lbs it's gonna be fine. Most 150/160hp cubs clock in around 1150ish and up to 1200. Just get your tires and prop on and get some brake boosters so you have the stopping power to bring that weight to a stop.
    Likes DENNY, BC12D-4-85 liked this post
    Feb 2021
    19
    Good to hear! It'd be great if some of that equipment I pull pays for the other upgrades.
    2,335
    How much cub time do you have? Might be best to spend all that upgrade money on gas. I know very few pilots that can actually tell you the difference between a 1/4 tank or full tank of fuel (75 lbs) without looking at the gauge. Nothing wrong with doing upgrades when needed, but for everyday flying a cub really don't care about a little extra weight. I would NOT move the oil cooler to the back of the engine, Makes working on mags, oil screen, muffler a pain in the butt. I do like going to a newer battery when the time comes, replace all the cables when you do it. You can put all you survival gear back where the battery was (duckbill anchors, ropes, tools, ect) if you want more weight in the tail. What part of the country are you flying in and what is the mission that will determine the tires and prop. DENNY
    Likes Pete Schoeninger liked this post
    Nov 2015
    Fairbanks, AK
    60
    This gets deeper into it but what kind of floor is in it? Metal? Wood? What thickness? I can get into details on flooring that will open eyes about weight differences that a lot of people might not realize.
    Extended baggage? Upper? Lower? Secondary exterior baggage access doors? This stuff adds up and if you donít need them for your mission itís something to consider.
    The devil is always in the details and if youíre a complete weight nerd thereís things that can be looked at with a critical eye and an open wallet to achieve a goal. Swapping out certain items within legality parameters with aluminum for steel, carbon fiber for either one etc.
    Panel stuffed full of ďmight need thatĒ items, depending on your flying needs, thereís some pounds to be saved there.
    Not only your starter but what size alternator are you running? Need to get weigh off the nose? Consider a direct drive alternator and lose the alternator brackets, the drive belt, and even the belt drive sheave. Could even go to a replacement lightweight ring gear support if you wanted to spend the dough.
    I could go on into smaller details like various hardware options if you want to really split hairs but that stuff is mostly choices during the build phase. Thereís a fair number of ounces to be had in that category if youre paying that much attention to the tiny details.
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,418
    Seats are likely more than 5 pounds. Remember the 90% rule. You don’t need a 5 hour seat if 90% of your flights are less than an hour.
    floor boards are often much heavier than necessary
    light weight starter, alternator and battery will go a long way.
    It’s a start. Tom Ford is the expert on getting the weight out
    Hope this helps
    Very Blessed.
    May 2017
    876
    Sutton exhaust saves about 6 lbs and gets rid of the muffler AD.
    Likes KevinJ liked this post
    Dec 2016
    Canyon, tx
    759
    If you can live with the idea of hand propping, here’s a weight reduction in the right spot.
    Jan 2017
    Utah/Alaska
    259
    Aluminum struts, no upholstery, leave it in silver for the fabric, no color...move the battery closer to the starter.
    RaisedByWolves's Avatar
    Feb 2005
    4,382
    Aluminum lift struts will take a bunch of weight off right away. Ditch the vac system, does it have old radios? Get some trig, and use the built in intercom. Metal headliner is heavy. Ditch the tank covers for carbon fiber. Narrow carbon back seat and bottom. Carbon fiber nose bowl and top cowl. Light weight starter, alternator and oil cooler. You can use the stock location. Carbon fiber pulley covers on the wing and inside the fuselage. Sport aircraft seats are light and comfortable.
    Nov 2002
    Fargo
    775
    What’s the weight difference between the carbon fiber floor boards and 1/4” birch?
    Jul 2014
    Norman wells, NT
    83
    what ever you end up doing I'd like to see some b4 and after panel pics especially. I went through the same process 6 years ago and regret not yanking the vacuum system. Mine is an A model as well and at 1147 lbs empty now
    Feb 2021
    19
    Whew that's a lot of help, thanks folks! I hadn't considered the floorboards, new ones would add a lot to to the plane aesthetically. Also really like the look of that sutton exhaust. The 100 hour engine swinging muffler AD seems like a real pain especially as I fly a lot. I think the panel will look a little empty for a while, maybe there's a full panel redo down the line to get the electrical there as well, but it's lower on the priority list.
    Just looked at the Atlee Safari Seat - wow it saves a ton of weight, not cheap for a folding chair though!
    Aluminum struts would be great but I've already got the Univair sealed struts, and can't justify that big cost.
    I like that lightweight radio idea, currently has a big old brick of a radio in there.
    Feb 2005
    4,382
    You can see his light weight seat at the bottom of the page
    http://www.carbonconceptsak.com/products.html
    cubdrvr's Avatar
    Jan 2002
    1,214
    Quote Originally Posted by don d View Post
    The pilot!!
    Don is quite possibly the smartest guy here.
    Why do we leave no stone unturned to minimize every extra ounce of weight?
    Now we add Bushwheels, heavy prop, heavy shocks, big tailwheel, belly pod, tool kit, survival gear,
    bigger fuel tanks, etc. Throw a buddy in the back seat, add all our camping/trip gear, fill with fuel
    and look for a 300' strip to land on.
    I'm a novice at cub knowledge compared to most of you......but I've been flying them since the
    early 70's. They always get me where I'm going........light or heavy......and always fun!
    Likes Bill Rusk, phdigger123, sharp liked this post
    Feb 2021
    19
    So I'm kind of getting to the understanding that they fly fine regardless. Part of the motivation for removing the vacuum and instruments is that I don't want to have to fix them when they break. I'm thinking I'll start wit the few minor changes and then just fly it for a while.
    Likes DENNY, sharp, hotrod180 liked this post
    aeroaddict's Avatar
    Mar 2016
    Boise ID area
    157
    I'm always working on the pilot weight reduction!
    It was mentioned in your first post; the battery. EarthX certified battery is 5.4 lbs. That's usually a great weight reduction.
    2,335
    3 or 4 years ago the top 5 out of 15 in the bush class at Valdez all came in within a combined distance (takeoff and landing) within 9 ft of each other. The weight difference between heaviest and lightest of the 5 planes was around 300 lbs. The top 5 had a fly off at the end and the winner was at least 200 lbs heavier than the light 1,000 cub. Just go have fun, you need a lot of hours in a cub before weight will matter. If you are going to fly in winter I would stick to a stock or hotrod muffler.
    Feb 2005
    4,382
    Quote Originally Posted by cubdrvr View Post
    Duh, it's easier to make the cub lighter
    Likes 40m liked this post
    10,555
    If you have never flown any Cub type that is really light you can't understand what a delight a lite Cub is to fly. Not talking take off performance but just a sweet flying Cub. I have flown over 20+ different cubs and the best flying one of them all is a 37 hp E2 Cub at 554 lbs. A really ratty 65 hp J3 with pealing paint and 50 year old fabric comes in second. The 4 90hp pa11s come in third. If you haven't flown a Cub under 700 lbs you wouldn't understand that less weight is the biggest performance mod
    Likes Bill Rusk, dstr59 liked this post
    10,555
    Raised by wolves has a very light nice 160 hp 18. Ask him how hard his 3 member gets flying a C90 Pa11
    Scooter7779h's Avatar
    May 2004
    Anchorage, Alaska
    1,046
    Start at the dinner table. Unless your a 120lb guy already, you best dollar to weight reduction is quit eating bread and drinking beer.
    PA-12 fan
    9,513
    We don't all have the disposable cash Mr. Ford invested into his cub to make it light...
    So some ideas and methods that work well. My budget dictates a method of financial need-
    Remove stuff that Is not used: your fuel pump for the belly tank is a good example. Put it in a sealed bag and store it for the time you decide to head up here to Alaska, and want the fuel.
    Instruments? Maybe wait until the vacuum pump fails, then pull them. But that is a personal choice.
    Next, upgrade when things fail- instruments, either remove or replace with lighter options. Battery switch to light weight (currently have Earthx); radio to smaller/lighter, starter and alternator...
    Third are dollar for pound ratio options: floorboards, side panels (what do you have as these are sometimes very heavy), Starter, Alternator, Carbon all over where possible....
    A guy can double the price of the plane with upgrades. Often times practice and acceptance helps a bunch. Funny thing is, they fly better adding some weight: Thurst line, Keller Flaps and VG's make them nicer, but are weight.
    One other big ticket item might be the fabric. If it has Razorback, that is a lot of pounds on the bird.
    Apr 2018
    Knoxville, Tn.
    235
    It's all about compromises. Weight, balance point, performance, safety, convenience, comfort, range and even appearance are interacting factors. Change one and it affects all of the others. Go to extremes on one of these things and you get a plane that loses out on the others.
    So everyone has an ideal in their mind of what their plane should be like. I personally think that the overall capabilities of generalist plane is more suited for me than a specialist plane. I have a wife with a medical issue that makes her dependent on me, so I personally value safety pretty highly over everything else. That means I'm not going to be landing on 400 foot sandbars anyway. I want to have a really good medical kit in the cargo area at all times, so it is a fixed part of the weight and balance. I also want the weight and balance shifted more toward the front because that means less chance of a ground loop, so one of these days when i can get good advice on how to do it I want to get an under the seat battery. My plane came with a lot of older panel instruments so I downsized by getting rid of all of the vacuum pump driven stuff and got a lightweight Aspen Evolution PFD and added a JPI engine monitor. I want to use the Cub for maintaining my IFR proficiency and I also want to be IMC capable in case I get caught in a VMC into IMC situation (safety again), so I still have a little more weight on the panel than somebody else would prefer. Not trying to offend anyone, but I would rather not travel at the speed of a constipated turtle and 8.5 tires are probably good for any maintained grass strip in the lower 48, so 8.5's it is. Big tires would sure look cool though. I'm OK with not being one of the cool kids...
    No, not really, but that's what I keep telling myself.
    Likes cubdriver2, Utah-Jay liked this post
    Feb 2005
    4,382
    Shhhhh donít tell them that. A 90hp supercub flyís nice. But a light weight 160 is a dream. pa-11ís,they arenít that nice to fly. Just kidding. If I was flying by my self all the time a -11 would be the most fun. Like someone said CG, itís sucks adding 10 lbs to a light cub but when you add it in the right place it makes a difference
    Dec 2016
    Canyon, tx
    759
    No kidding. Must be nice
    Dec 2016
    Canyon, tx
    759
    It would also be interesting to know the cgs of the 5 cubs and if there was a correlation with aft cgs. I suspect, like always, it’s more about the monkey sitting in the seat and who had a good day.
    Likes DENNY liked this post
    20,650
    You have motivated me to go on a diet.
    Weight savings is a never ending deal, it is like crack, you just want more or in this case less.
    11,421
    Years ago, we went through a “lightening” program on our heavy Cubs. Lightweight alternators replaced heavy generators (and work better), lightweight starters, aluminum oil coolers on rear baffle, and under seat Odyssey battery. A few other simple things, but generally, that took an average of a bit over 40 pounds off each plane.
    Vacuum system: They’re heavy, and prone to failure. In a Cub, you likely won’t need it much, and when you do, it may not be functional. I’d vote to remove it, and the gyro instruments associated. But that said, I’m also a believer in a “get out of jail” attitude instrument. Look at uAvionix new AV-30C attitude gyro. Super light, multi functional, etc. add its temperature sensor, and it calculates and displays Density Altitude. It switches back and forth between Attitude instrument and DG.
    Put one of those in place of one of the gyro instruments you removed. Multi functionality, and the things weigh hardly anything.
    9,513
    Last night I remembered a conversation I had years back as we were fighting the compass in a cub, no matter what it would read north due to the location and metal around it. The mechanic I was good friends with came into the conversation and started laughing, and reminded us that the compass was archaic and would always be a problem. "Put a hand held GPS in and don't worry about it!"
    It made sense. We quit worrying about demagnetizing the plane, and all the other stuff. The GPS paid for itself in fuel over the next year, and was handy.
    Today we pilots have a plethora of easy options for "Getting out of Jail" in bad weather. iPad Pro: $950, Strtux antenna: $250, FlyQ Electronic Flight Bag Subscription with IFR charts: $159/year (The sometimes do lifetime subscription deals also); For less than $1,500 you have more information at your fingertips than airliners had ten years ago, including ADSB and synthetic vision.
    That is a whole lot less weight also than a full panel, GPS radios, antennas and coax. Best part is with a little velcro a guy can stick the iPad when desired to the panel and remove when not needed to help seeing out, and it is not installed equipment so the FAA does not care.
    My iPad has actually lasted longer than my last vacuum pump.
    Likes Utah-Jay, C130jake liked this post
    Feb 2021
    19
    I'm moving over from a 90hp Cessna 120, which is the nicest flying plane I've ever been in. Much more lively than the super cub on the ground, but the light control forces are so nice, a friend says they're lighter than an R22. I'm in SLC so I've quickly found the limit of how fast the 120 will get off the ground at places like Cedar Mountain, which is at 7000 ft. I'd like to get into all the Utah desert strips, and with Idaho so close, am planning to spend a week or two up there this summer bouncing around and seeing as many interesting strips as I can. The 120 would do lots of them, just wouldn't have the margin I like to do the more interesting ones. Part of the weight savings is some desire to stay legal on w&b, and I am considering the 2000lb gross kit. I like the AV-30 idea quite a bit and it would make the panel look a little less empty after the air powered stuff is gone.
    Denny, what's the cold weather issue with the Sutton exhaust? I do lots of flying in the winter here, it's not crazy cold but I'm often flying in the teens. Hot rod looks like a good option.
    Utah-Jay's Avatar
    Aug 2020
    Heber City, UT
    203
    Quote Originally Posted by alexstoll View Post
    Alex, are you new to SLC and from WA? Reason I ask is we might have met at UT9 the day I solo’ed
    Jan 2021
    Nevada
    16
    Quote Originally Posted by Tennessee View Post
    Thank you!
    "Constipated Turtle" is a great name for an airplane! I had another name in mind , but now I'm not so sure. "Constipated Turle" sure has a ring to it - and is very memorable.
    Thanks Tennessee thanked for this post
    2,335
    A Sutton will work but A Hot Rod exhaust will keep you warm even well below O degrees. I have a dedicated defrost, normal cabin heat is ducted to back seat and that scat tube temp is over 200 degrees. Also have great carb heat. Coming from a low HP aircraft you are going to really like the 150hp cub. Prop will make a big difference so test fly a few if possible. A good test to see if spending a lot on lightweight mods is simple. Fill both tanks, fly for 1 hour (that should be about the 50 lb weight loss you want) now ask yourself if you notice any big change, do a landing, and takeoff. On a cub the three things than really make a difference are Borer prop, Bushwheels, and AOSS.
    11,075
    Don't be too quick to move the battery forward. The only advantage is to save 2 or 3 pounds of cable at the most. 150 Cubs are nose heavy in the first place. Set up a weight and balance program on your computer. Move a few weights around to different locations. Watch how the CG shifts. Too far forward coupled with an expedited braking action could mean a new prop and perhaps an engine. Piper put the battery back there for a reason.
    Likes Steve Pierce, MZ18 liked this post
    May 2017
    876
    The other thing to consider, with the EarthX, do you really want to be sitting on top of a Lithium battery? While the technology has improved, my EarthX EXT900 TSO will be forward of my firewall on my PA-16. Just not 100% convinced that there isnít a fire hazard yet. Donít want that possibility in the passenger compartment.
    Feb 2005
    4,382
    Must be. George can you send me some of that money? I find it by working until 2 or 3 am.
    11,421
    That is assuming, of course, that you replace the "standard" battery with an Odyssey or other light weight battery.
    And, I agree that I wouldn't want a lithium battery under my seat, just yet..... But, the Odyssey works fine there or in original position.
  1. Replies: 4
    Last Post: 09-24-2020, 04:25 PM
  2. Bush wheels..extended landing gear. How much weight is added to all up weight?
    By kiwi in forum Piper: PA-18 Super Cub (and L18C & L21)
    Last Post: 05-22-2020, 06:08 PM
  3. Removing the oil cooler
    By petterfilip in forum Modifications
    Last Post: 02-12-2013, 11:33 AM
  4. Removing oil Filter
    By snowyriver in forum Cafe Supercub
    Last Post: 12-14-2011, 12:37 PM
Tags for this Thread
