Results 1 to 21 of 21
Thread: Aileron woes
    Kodiakmack's Avatar
    Sep 2020
    winters in Utah, Summers in Idaho
    126
    Aileron woes
    Looking for some advice about rigging ailerons on the -12. We weren’t getting correct throw, and the rod end/bearings were corroded badly. So we replaced the rod ends and are trying to get rigged but are struggling.
    We’ve read everything we can find, and the erection manual seems way too easy. We’ve rigged the down 25 degrees with the rod/bearings, but to get the ailerons to be at trail or slightly low, and still get full throw (31 up 25 down correct?), we only have a couple threads in each side of the barrel on the balance cable, and the control cables on both sides are as tight as they will go. We don’t dare keep so many threads showing on the balance cable but can’t think of anything else to do. High praise to whoever is willing to call and explain or explain here.
    HAVE FUN. DON'T DIE.
    Sep 2004
    Illinois & Wisconsin
    776
    Is it a new fuselage or an original?
    Sep 2004
    776
    Are the stops on the control torque tube set correctly to allow enough throw side to side?
    Kodiakmack's Avatar
    Sep 2020
    126
    Yes. I opened them wide open so that they aren’t interfering at all.
    WhiskeyMike's Avatar
    West Boxford MA
    956
    Quote Originally Posted by Kodiakmack View Post
    are you sure about 25. I thought it was more like 15 down.
    Kodiakmack's Avatar
    Sep 2020
    126
    2,331
    Did you check the travel before you started working on it. Might have been off before you started. Start from scratch and right the wings then controls, may need new cables.
    Kodiakmack's Avatar
    Sep 2020
    126
    They were under to begin with. Control cables are an absolute last resort. Currently removing a link at the control horn and fabricating new slightly longer link.
    11,071
    Check that the bellcranks in the wing are in the neutral position before you start. Adjust the length of the pushrods so that the ailerons are in neutral. Set the travel stops last.
    If the bellcranks are not in the correct position in relation to the surfaces, the surfaces will not be in their correct position. You should not need to be modifying the airplane by changing the link.
    I haven't rigged a PA-12, this would be a standard procedure for any airplane with this type of system. If the bellcranks are not correct in neutral, you will tear your hair out wondering why!
    3,808
    On my -12 the bottom of the stick where the aileron cables attach is extended by an inch or so. It's a bolt-on piece, and operates to give more cable travel for a given stick deflection. I don't recall offhand if that's factory, but the stick geometry is different between -12 and -18, presumably due to the greater control surface travels on a -12.
    Likes cubpilot2 liked this post
    Kodiakmack's Avatar
    Sep 2020
    126
    Thanks for the advice. As for starting my with the horns centered, I feel like that’s essentially what one does by putting the horn at the physical stop with the aileron at it’s down spec, in this case 25 degrees. Much more accurate than trying to eyeball or measure ‘centered’. The ideal thing would be correct length cables. IA and Dad-Chanic both are on board with slight modification to make it work.
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    800
    Here's 3/4" per shackle.
    11,071
    Not true. As the bellcrank rotates, the amount the aileron moves varies. It will only be correct when the stick, the ailerons and the bellcrank are all in the neutral position. This is adjusted by varying the length of the push rod from the bellcrank to the aileron.
    If the aileron is in neutral and the bellcrank is not, you will be forever messing with it. They must both be in neutral, then you adjust the stick to neutral. Then you set the stop limits.
    Kodiakmack's Avatar
    Sep 2020
    126
    Are the limits you’re talking about the stops in the wing the bell crank hits or the internal moveable stops?
    11,071
    If you have two sets of adjustable stops. The ones in the wing are set to the limits specified 31 & 25. The ones at the stick are set so that they are loose when the wing stops are met. This is to ensure you have full travel with the air loads on the ailerons. The cables "stretch" slightly against the air loads so the wing stops are the actual limits.
    behindpropellers's Avatar
    NE Ohio
    6,894
    Post a picture of the connection at the bottom of your torque tube.
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    809
    ive seen a couple of PA12s converted to the 18 torque tube assembly to which they had overlooked adding the extension back on. It will change the travel.
    Ed
    Kodiakmack's Avatar
    Sep 2020
    126
    We got it : ) and I can now see what you meant by ‘centering the horn’. Both our methods achieve the same thing, I just think we had a language separation.
    anyways...
    we put our new link in and tensioned/rigged until we got ailerons centered at stick centered with 31 up and 25 down +\- 0.4 degrees or so.
    happy days!
    Likes Utah-Jay, windy, Charlie Longley liked this post
    Jul 2012
    Montana
    471
    Whew
    Sep 2004
    776
    While doing a ground up restoration there are literally hundreds of those “whew” moments, especially if it’s a 12. Scariest ones are cutting the last few new holes in an almost finished instrument panel, cutting down the windshield to fit the frame, and the biggest “whew” comes after weighing it and finding it’s 50 pounds lighter than you hoped for and the CG is right where you needed it to be.
    You made the right decision to post your questions here before you went off on your own. It tells you’ll do just fine
    Likes Pete Schoeninger liked this post
    Kodiakmack's Avatar
    Sep 2020
    126
    I’m very glad we’re not doing a ground up. MT12 did that for me in 2012 ; ) but it was one of a few whew moments we’ve had doing this deep annual. That new panel is getting a few last holes next week and then we’ll be flying shortly after : ) I’m lucky to have my a&p as a dad with over 50 years in this world. He’s saved my back. And taught me so much this winter.
    Thanks petey451 thanked for this post
    Likes windy, Hardtailjohn, petey451, astjp2 liked this post
  1. Engine woes
    By PA-22/20-160 in forum Cafe Supercub
    Last Post: 10-24-2018, 04:19 PM
  2. Hot start woes...
    By WindOnHisNose in forum Super Cub Sick Bay
    Last Post: 08-30-2018, 04:25 PM
  3. Compass Woes
    By cplne in forum Super Cub Sick Bay
    Last Post: 05-09-2018, 12:25 PM
  4. Transponder woes...
    By Taledrger in forum All Things Electrical
    Last Post: 08-23-2016, 05:15 PM
