Results 1 to 14 of 14
Thread: Tail Spring Bolts
    Dec 2012
    Camas, WA
    120
    Tail Spring Bolts
    Changing my tail spring today, was thinking that replacing the four bolts would be a good idea too.
    Anyone know the exact sizes off the top of their head?
    Dec 2012
    Camas, WA
    120
ID:	54361Click image for larger version.
ID:	54362Click image for larger version.
    20,518
    You have an Alaskan Bushwheel tailspring. I use an AN 6-25A bolt with a grade 8 washer on the spring side and an AN363-624 nut to hold the spring to the fuselage. AN4-16A bolts, AN960-416 washer and AN363-428 nuts for the tailspring plate. AN7-21A bolt, AN960-716 and a grade 8 washer and an AN363-724 nut for tailwheel head to tail spring.
    Thanks sjohnson, Olibuilt thanked for this post
    Likes Chogf22 liked this post
    G44's Avatar
    Oct 2011
    SW Michigan
    666
    Yes, change them! I had my bolt that holds the head onto the spring fail while slow taxi. Low time and no rough use.
    Kurt
    Dec 2012
    Camas, WA
    120
    Thank you fellas!!!
    sjohnson's Avatar
    Boise, ID
    738
    Steve,
    Where do you source the grade 8 washers? I want to make sure they're really grade 8 and not some knockoff. The ones at McMaster seem larger than AN960 equivalent.
    The modern equivalent of the phrase "lions led by donkeys" is "innovation led by lawyers".
    JP's Avatar
    Mar 2003
    The Big Woods of Maine
    3,267
    Good idea to change on occasion. Tom Ford has a great story about a bolt that broke and John Meade has a follow on story about a gang of pirates who stole a tailwheel.
    JP Russell--The Cub Therapist
    1947 PA-11 Cub Special
    20,518
    Steve,
    They do have a larger OD than an AN washer. I usually get them at McMaster Carr but have also picked them up at Tractor Supply in a pinch. Best thing I did was convert to a two bolt tail wheel head and spring. No more loose tailwheel to spring.
    Thanks sjohnson thanked for this post
    Likes jrussl liked this post
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    804
    I like drilled bolts and castle nuts for the big bolts. Lock nuts tend to loosen up after a while.
    Likes jrussl, cubscout, algonquin liked this post
    20,518
    Quote Originally Posted by txpacer View Post
    I have wondered if they loosened or stretched. I started using the AN363 steel look nuts because I thought they were loosening buti don't think they were, I think the bolts were stretching.
    Likes sjohnson liked this post
    Sep 2002
    Southern NH
    803
    Yep, had a fiber lock on my wheel to spring bolt 2 summers ago. Had to re-tighten several times on the way to AK. Went into Stoddards and in one of the aisles there was a bin labeled “Cub tailwheel to spring hardware”. Bolt, washer, castle nut and cotter pin in a ziplock bag. Forgot how nice it was to have that kind of parts house just down the street..
    3,414
    Bolting through the double leaf springs has never made sense to me.
    Spacer/bushing or not, seems like you couldn't tighten up the bolt properly
    without binding the springs and/or putting some shear forces on the bolt.
    sjohnson's Avatar
    Boise, ID
    738
    Steve, do you put a washer in the fuselage, under the nut?
    20,518
    I do, I like the Grade 8 especially of there is no bushing welded in the fuselage fitting yet.
  1. Tail spring
    By buckeye in forum Modifications
    Last Post: 01-29-2015, 02:31 PM
  2. Tail spring for PA 11
    By mvivion in forum Cafe Supercub
    Last Post: 10-17-2014, 12:35 PM
  3. tail spring pad
    By M1 in forum Super Cub Sick Bay
    Last Post: 03-27-2006, 03:17 PM
