Figures, I got rid of the front mount cooler and I need to change the hard lines to soft on another cub. Does anyone have the length for the soft lines running from the front cooler underneath to the acc. case ?
32” and 38”
RaisedByWolves thanked for this post
Oliver thanked for this post
The line that runs on the right side is the 38” and sometimes it can be a pain to get it by the throttle cable bracket.
Fun Fact, Univair has a kit for it
https://www.univair.com/piper/stodda...ler-lines-kit/
40m liked this post
Damn Ford, wonder if those fittings are 24ct gold?
RaisedByWolves liked this post
At least they give you the part numbers to source parts elsewhere.
Do the lines go "under" or "over" like the hard lines?
Later model cubs came from piper with soft lines ran under
https://www.supercub.org/forum/showt...ckets-now-what
daedgerton thanked for this post
Aircraft Spruce does a pretty good job of building custom length lines-
https://www.aircraftspruce.com/catal...?clickkey=9950
$470 for the AE466 brown silicon fire sleeve hose and all 4 fittings.
