Getting Advice ! What angel should the lift strut attach bracket be welded to the lower longerons? The Strut attach fitting on the wing is set to 21* 45' (21 degrees . 45 minutes) should the strut attach fitting on the fuselage be set the same? I've been told to set it at 22.5* decimal angel. ( 22 degrees. 30 minutes)
