Throttle cable bracket
Mr. Ed
MEMBER
PNW
I have the Northland drawings and have searched on line. I’m looking for the small tab that the throttle cable anchors to at the upper end prior to the throttles and where it is mounted (measurement from the forward throttle or any other point of reference)
Thanks for the help.
IF I understand your question correctly, I believe the information you need can be found in DWG 12183, section B-B (part number 81172-33), and DWG 13388 section C-C; if I misunderstood, my apologies ... .
That’s what I was looking for, thank you!
