In order for any single engine plane to be certificated in the normal category one of the requirements is that it be able to recover from a spin. First it must complete one full turn, then it must stop the spin prior to the completion of the second full turn. I did the flight testing to certify the EDO 696-3500 amphibious floats on the Cessna 185 with my 185. For the spin portion of the testing, the plane was loaded to the aft CG limit at max gross weight. The spins were done in both directions. Some with the power at idle. Some with the power at full throttle. Some with the flaps up and some with the full 40 degrees of flaps down. Some with the ailerons into the turn and some with the ailerons against the turn. The nose was pointed well down in the turns. In none of the spins was recovery ever a question. Lots of spins.
These spins were done during the investigating phase of the testing and again during the demonstration to the FAA. After this demonstration the airplane is placarded "Intentional Spins Prohibited". In order to remove the no spinning restriction, a six turn spin must be completed prior to stopping the spin in one turn. There is no advantage for a float plane to be certified to allow intentional spins.
Due to the floats hanging low the plane does spin a bit more nose down than a plane without floats. If you have wing tip fuel tanks and spin with one tank full and the other empty, it will turn faster in one direction than the other. Spin testing is required for extra fuel tank installations also.
My take? A spin is a spin. Floats or no floats. I did spin testing with my E-AB TCOW Cub on floats. Chances are few pilots have done intentional spins with float planes since they are taught that "Intentional Spins Prohibited". When I did these spins the airplane was licensed in the Experimental-Research and Development category.
