My 180 is heading for annual. What’s the experience been doing the required inspection?
What is your parts list?and $150.00 in parts if all is well and if all is not well you REALLY needed to do it.
if needed.
sj
George which “Bushwheel Bill” mods are you referring to?
Another view, it WILL be needed in the future, and if things go bad they go really bad. Why not just spend your lovely bride's money and do it while you have it down?? No, no idea of the cost, but prevention is often the best and least expensive solution......
I disagree. Maybe it will, maybe it won't.
In any event, the AD has a recurring inspection requirement.
Cost: the QMI kit is about $3K, plus installation labor.
I haven't done the tail inspection yet, but when I do,
I will repair the hockey sticks .... if they are damaged.
Also any other components back there that are damaged will be replaced / repaired.
Otherwise, "if it ain't broke, don't fix it".
...... but if you need to pull the tail off, might as well extend inspection times with the kit.......
Looks interesting. They are using a doubler on the ribs so that they can have a good hole to rivet the new skin to.Some progress for the complete rebuild while in for the AD
