Dave Calkins thanked for this post
Good Pun!
Great idea, but seems that a press fit would have been the answer- freeze it and pop it in, but not be so tight it splits the material it is going into.
Love Bushwheel Bill's answer, seems well thought out and executed.
Dave Calkins liked this post
I ordered the QMI kit as I’m about to do my tail inspection. Hopefully I don’t need it. I was going to return it if I don’t need it, but then I noticed in Bill’s video where he says that installing it takes the inspection from a 5 year requirement to 10 year requirement. Is that true? The stuff I read from the feds seems to contradict what he says in the video. Looking for clarification.
Did he obtain an AMOC to the AD? This was discussed on BCP or the club fb page and I thought the answer was no. So, AD trumps STC.
hotrod180 liked this post
Took the tail off a 185 today due to a bushing used in the co-pilot hockey stick... Big No-No to do because oversizing the attach hole makes for a too small edge distance for the attachment...
Here is the offender...
And here is the other side, which is actually fine...
The too short bolt used with bushing that was on it... the threaded portion was riding on the inner bracket and wound up damaging that part also... Have a tail section off a 182 we did a tail wheel conversion on that I am able to rob a good inner bracket off of..
I ordered a QMI kit and Bill sent it NDA for me..
Brian
QMI installed... Quick and easy relatively speaking... only complaint I have is the drill jig was a PITA to set up.. I wound up grinding a little material out of the inside section of it so it would slip in between the inner bracket and new QMI piece easier..
QMI part in place for drilling...
Part installed and drill jig in place...
Finished this side...
These are the two sides cut out of the hockey sticks...
Took about 6 hours including complete tear down and reinstall of the tail surfaces to flight status... Next time the aircraft will need the AD inspection is 1500 hours or 10 years.. Then back to 500 hour 5 year inspections..
Considering the owner of this airplane he will probably be due for AD in 4-5 years then about 2-3 years after that... This bird is a worker in a Alaska Lodge, will be on floats in a week or two..
Brian...
I hope I’m wrong, but my understanding is that the QMI kit doesn’t change the time interval on the AD because the STC’s ICA don’t constitute an AMOC.
That is, the AD time is set by the AD and if you use the QMI kit to comply with the AD, it doesn’t change the time.
To me as an IA the QMI time and AD time are irrelevant. With the QMI kit I am not gonna see a reason to remove the stab, most everything else can be seen with the tail on from what I have seen and the part that QMI fixes, I can still see with my borescope post QMI install.
