Results 1 to 22 of 22
Thread: Props for PA18A 150
    Oct 2020
    8
    Props for PA18A 150
    I just measured my prop from tip to tip and it is 84". I have a 19" clearance to the pavement when the plane is sitting on the tail wheel. The climb performance is great and cruise at 22.5 is 95mph. Is this a standard size prop for a super cub? I was also wondering what my clearance might be when I do wheel landings. Any thoughts or advice.Click image for larger version.
    Sent from my SM-T560NU using SuperCub.Org mobile app
    Dec 2016
    Canyon, tx
    708
    Are you sure it’s not an 82-43/44 borer?
    Oct 2020
    8
    That is Greek to me. Is that a standard type of prop for this plane?
    Wolf Lake, AK
    5,907
    What do your logs say?
    Dec 2016
    Canyon, tx
    708
    Or take your spinner off and see what the hub says.
    11,332
    What these guys ^^^ said.
    IF that is indeed an 84 inch prop, it’s not legal, unless someone found that long a prop and got it field approved.
    Much more likely, that is an 82 inch diameter “Borer” prop. The prop designation is diameter first (82) then the prop pitch (for a Borer it’s typically somewhere between 41 and 44, and represents theoretically the forward distance the prop would pull itself through the air or some dense medium IF there was no drag or other factors involved, a theoretical measure).
    As Kevin suggested, pull the spinner off and look at the side of the prop hub....it should have the designation stamped there.
    Oct 2020
    8
    Thanks, I can understand that. I have come a long way but have much further to go. Thanks again.
    831
    The “standard” Supercub prop is a Sensenich M74DM-53 to 58. You have a McCauley prop, most likely a Borer prop as others have said. There would need to be an FAA Form 337 in your paperwork for that to be legal. If you are not aware of your responsibilities as an aircraft owner as it relates to required documentation, I would strongly suggest you get ahold of your mechanic and pay him for a couple hours training!
    Likes DENNY liked this post
    Wolf Lake, AK
    5,907
    If he doesn't have required documentation he should call his mechanic and fire him.
    Clearwater,Fl
    2,564
    Locate the STC for the propeller. Read it and be sure the aircraft records and equipment comply. STC SA00562SE can be bought from cub crafters.
    http://store.cubcrafters.com/McCaule...ly_p_1860.html
    Feb 2006
    N. california
    124
    Sounds like an inaccurate measurement.
    get that spinner out of the way, check model designation on prop. Verify in records. And report back!
    Feb 2015
    Anchorage
    69
    I just pre-ordered the Sensenich ground adjustable prop. I can’t wait to try it out! There may be quite a few used Borer props on the market if they really are as advertised.
    Likes OLDCROWE, akavidflyer liked this post
    akavidflyer's Avatar
    Apr 2010
    Soldotna AK
    161
    Quote Originally Posted by md11freighter View Post
    They really are. I think the 2 big ones, WW and Sensinich are really close in performance, but the Sensenich wins hands down for ease of pitch changes.
    FWIW, the pitch pins that come with it are in 2" increments. My 160 doesn't like anything over 38 (that's only if I want to go faster but not get off the ground quick). I took the 40 size pin and turned it down to 35 and that really seems to be the sweet spot for the 150/160 HP engines. Still faster in cruise than the 82/44 borer but gets me off the ground MUCH quicker. We have tested it on A LOT of different planes now and ALL have shown a major improvement over the Borer prop (not to mention its 12 pounds lighter and the throttle response is instantaneous)!
    When playing with the prop, CHECK YOUR TACH!!! None of the mechanical tachs we have tested were even close. Typically they have been 150-225 RPM off on the top end so the guys that thought they were turning 2700 on take off (like me) were only getting 2475-2550. I was really wondering why I was cruising so slow at 2450 (turns out I was only turning 2250). Optical tachs are cheap and my new digital tach reads within a few RPM of the optical tach now.
    Apr 2017
    ND
    166
    not saying it is right, but I have seen an exception to this rule. A reissue of an airworthiness certificate while non standard prop is already installed.
    Likes DENNY, dgapilot liked this post
    831
    Quote Originally Posted by MoJo View Post
    Yeah, I’ve done that where an airplane comes back from Canada or another bilateral country, and their CAA approved the other prop. That’s about the only way, and if that’s what you hang your hat on, you better keep a copy of the 8130-6 application for airworthiness certificate with the DARs signature. That’s your only document authorizing it. If it doesn’t have an approval from another CAA, then no joy! DARs have to conform the airplane to the TC or other approved data.
    Jan 2005
    Fowler, Ks
    618
    Quote Originally Posted by akavidflyer View Post
    I would like to see numbers comparing the borer 82/41 ..150 horse to Sensenich. Ground roll etc
    I ran a McCatto on a 0-290 and loved the ‘lighter’ and of course the performance but with my 0-320 I would like ‘legal’ also.
    Likes jrussl liked this post
    3,412
    It's been several days but the OP hasn't posted the model number of his prop yet. ??
    I believe that there's an 84" borer available for the 180hp SC,
    guess it could be installed on a 320 but you'd need different drive lugs on the flange?
    20,510
    The 84" McCauley that I have been around is the 1A200 on the Pawnee.
    Nov 2002
    Fargo
    759
    Pawnee prop is 1A235
    20,510
    Quote Originally Posted by PA-22/20-160 View Post
    That's it, only 84" I have been around.
    Dec 2016
    Canyon, tx
    708
    If it is 84”, I’ll trade you for a legal 82”. I suspect it was measured with a faulty measuring apparatus. I have two of them. One of them is used to measure TO and landing distance. It says I’m 20’ shorter. I also have one to measure height and length. It measures 2” longer
    Likes flynlow, RaisedByWolves liked this post
    Oct 2020
    8
    Thanks to all of the great responses. I hope to have a chance to get to the hanger this weekend and I will do more investigating and figure out exactly what I have. Thanks and in will post the results.
  1. PA18A Differences?
    By NoCubYet in forum Cafe Supercub
    Last Post: 12-27-2020, 10:31 PM
  2. STC for 8.50 x 6 for PA18A
    By jsbc in forum Member to Member
    Last Post: 06-03-2018, 10:27 AM
  3. PA18A info
    By portfield in forum Cafe Supercub
    Last Post: 12-02-2014, 12:54 AM
