Results 1 to 26 of 26
Thread: Considering putting floats on my PA18-150
    Dec 2011
    32
    Can float fittings be put on a PA18-150 without requiring a major re-fabric effort?
    Aug 2014
    Kenai, Alaska
    194
    There are bolt-on rear fittings, not really pretty, but they work.
    Cubcrafters and others sell them.
    Upper Peninsula of Michigan
    587
    What fabric system do you have?.....pretty easy to patch most if you don't want clamp on fittings....It's not much welding put Atlee Dodge fittings on.
    11,345
    The clamp on fittings are simple and a no brainer. I wouldnt go to the time and effort to weld on fittings.
    But either way is not that big a deal. You’ll also have to cut a couple slits aft for clamps for pulleys. Again no big deal.
    9,461
    As I recall, it took me a couple days from start to finish to put floats on my cub the first go around, including bolt on fittings. I did most of the work myself, with a mechanic that would come over to laugh at me when I got stuck or needed help.
    Bolt on is pretty simple, and if you put up an advertisement you will find a set used I bet. Also, Eddie Peck might have some, or Sutton Air Salvage in Palmer would be a good place to ask.
    They really are not that big of a deal, but some folks say they can over time cause your longhorns to imprint or dent where the u-bolts ride. Weld on fittings have a habit of trapping water and causing corrosion. No free lunch.
    10,996
    The clamp on float fittings are part of the set of floats when they come from the manufacturer. They are also dependent on which make and model floats you are using. It is not a big deal to install the clamp on fittings. Usually some interior just needs to be moved out of the way to get your hand and tools in there.
    587
    Regardless of how you mount them....flying floats is about the most fun you can have in an airplane!
    Cranman
    FLORIDA/WISCONSIN
    220
    Note in parts on this website. I have a set of 2100A's for sale. They will be removed in February. Inside stored in northern WI.
    A gun is like a parachute. If you need one and don't have one, you'll probably never need one again.
    Thanks RookieCubPilot thanked for this post
    Likes RookieCubPilot liked this post
    Dec 2011
    32
    It sounds like clamp-on fittings are the way to go, at least until I decided to refabric the plane some day. Thanks for the responses.
    Cranman
    FLORIDA/WISCONSIN
    220
    Quote Originally Posted by mjdonovan View Post
    Mark,
    I can’t figure out how to respond to your private message. The floats are anphibs. They come with all fittings, gear advisory system, struts, etc. They are in excellent condition and have been hangared when not in use. Also they are fresh water use only. I am asking 40k as removed. If you pm your phone number I can send some pics.
    Jon
    Dec 2011
    32
    Jon, I just sent you my phone number and email via private messaging. I have some questions for you about the floats, and in general putting floats on a PA-18-150 with MGW = 1750LBS.
    11,345
    Simple answer to that last question: Don’t, this is specifically why Wipaire spent a LOT of money and time developing their 2000 pound gross weight kit. Amphibs could work IF you want to also install the 2000 pound kit. Otherwise, you’re likely looking at a single seat airplane on amphibs.
    RaisedByWolves's Avatar
    Feb 2005
    4,358
    Unless you build a light cub. Mines 1245 on anfibs Click image for larger version.
    Dec 2011
    32
    I agree. Without it, its a single man aircraft with about 9 gallons max of fuel on board based on my weight.
    Dec 2011
    32
    Are you saying yours is 1245lbs empty weight?
    Feb 2005
    4,358
    On floats. Yeah.
    Dec 2011
    32
    Wow. That is light. My aircraft is about 1200 lbs empty, on 850 wheels
    11,345
    What floats are those? Not Wips....and what do they weigh?
    Feb 2005
    4,358
    349 edo 339-JHS. Wouldn’t have mattered if I did the wip GW, it’s not mentioned on these floats. They give you a whopping 10lb increase in gross
    jk's Avatar
    Dec 2002
    over there
    480
    Whoa, did you use bathroom scales? Just kidding as that weight is amazing for an amphib! Good on ya!
    I started with a cub under 1000, and came away with just over 1400 on Wips. Thought those EDO’s were a little heavier.....
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,400
    He has me beat by 75 pounds. I’m 1325 empty on Wip 2100A’s with no electric retract pump. Just manual.
    Awesome job Tom.
    Very Blessed.
    10,500
    Quote Originally Posted by Bill Rusk View Post
    Awesome job Tom.
    I think it's a wash Bill, your shadow displaces less water.
    11,345
    All 150 hp Super Cubs increase GW to 1760 when installed on floats.
    Feb 2005
    4,358
    1070 on 31’s. There is no electric power pack. Kind of sucks with 150 pumps to get the gear to move. Takes 2 min. At least you’ll always know where the gear is by how tired your arm is
    Jul 2014
    Norman wells, NT
    81
    I'm just curious are there any other new manufacturers providing clamp on fittings? I had to scrounge big time to find a used set for my edo's....the price Kenmore quoted at the time was insane.
    10,996
    Quote Originally Posted by farm_boy252 View Post
    Why didn't the person who sold you the floats give you the fittings which belonged to them? Those fittings belong to the floats, not the airplane.
  1. Floats for PA18-95
    By supergoose in forum Cafe Supercub
    Last Post: 09-13-2018, 08:15 PM
  2. putting L21 glass on a PA18
    By skysigns in forum Cafe Supercub
    Last Post: 04-24-2016, 05:35 PM
  3. Putting a Scout on Floats
    By StitchF22 in forum Modifications
    Last Post: 05-22-2013, 06:11 PM
  4. Putting Floats on a J=5
    By Drisker in forum Cafe Supercub
    Last Post: 10-31-2009, 10:58 AM
Tags for this Thread
