topcubs365
MEMBER
My PA 18 project has a broken leg and I am looking for someone to repair. It is right side, 3 inch HD with 1 1/2 inch axle. Both down tubes are bent and broken. Any ideas folks? Maybe just buy new?
Price for new is short of $1000. Thanks for the response. MK
used to only be $300 in early 90's.... and a brand new factory cub was only $36000 in the 80's....
$563 for Atlee. Don't mix and match. The two vendors are different. The work is easy it is just talking the time to make another jig. I have jigs for PA16, 20 and J3/PA18 standard length. Probably easier at this point to just buy a new one.
I have never change a cabane vee when installing extended gear. Just the lower shock struts and the gear.
I didn’t know cabane v varied? Shock struts and legs did on extended gear, length & width(stance?)
Even gear made by the same manufacture can be different.
Bought a new set from Atlee years ago, went to install the outside axle for skis which slid inside the 1 1/2" axle, and they did not fit. That gear had an internal tube installed as a way to beef up the the axle.
There is no 'standard'.
I think Atlee originally just resold Jensen gear under his brand......
Sent from my iPhone using SuperCub.Org mobile app[/QU
Jensen manufactured the gear for Atlee because it was cheaper. After the fire at Jensen Lee Budde went to Colorado and bought all of the jigs that were actually Antlers. Rather that get in a pissing match over it Atlee made new ones. I got all that from Kracke.
