Results 1 to 22 of 22
Thread: Sensenich 82” GA prop STC approval
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,596
    So with the government everything takes longer than planned.
    But they did it. Sensenich got the STC for their 2G0M8 C82BGF, 82" prop for PA-18 with O-360.
    Compared to McCauley 82x42, approved tests show 140 ft/min climb increase +7 mph faster in flight level flight when pitched to same static RPM.
    STC for O-320 is coming next, hopefully this summer.
    Next year (2022) they expect to have trickle down approvals for small engines, other piper models, and even the C150.
    Press release to be out next week.
    Pb
    Transmitted from my FlightPhone on fingers...
    Thanks Gordon Misch, cubscout thanked for this post
    Likes gahi liked this post
    Dec 2015
    New Mexico
    69
    Is this the composite, ground adjustable prop?
    Dec 2016
    Canyon, tx
    721
    Peter, is this the prop with the whirlwind designed blades? If so, it seems like the rumor is that sensenich used the early blade profile causing higher CHTs. The newer whirlwind design has a slight cuff on the back of the blade improving cooling. Does that sound right?
    Thanks barrow pilot, Mattpeed thanked for this post
    Likes Nodak33 liked this post
    Aug 2018
    Alaska
    21
    Any guesses on price?
    ETA: just saw in an article, $6350 or $7085 with a matching spinner.
    supercrow's Avatar
    Dec 2008
    460
    I ran the Whirlwind for a year and a half. Very happy with it. Started running the 82 Sensenich early this fall. The Sensenich has a slightly different blade profile than the Whirlwind and I have had not heat issues with either prop on an 0320 with high compression. The Sensenich is easier to change pitch than the Whirlwind and is at least as good as the Whirlwind performance wise and is 2" longer. It pulls harder that my 43" borer did and cruises at least as fast at the 38" pitch setting. The pins allow me to go from 34" to 44" in 2" increments. I like them both and don't see myself going back to an aluminum prop unless these props don't hold up over time. Either of these props is a 15lb weight reduction right off the nose, which would be really welcome for a lot of 12 drivers. I only own 2 composite props because I always like to have a spare and I sold the borer. Flew yesterday on summit skis (no deep snow here yet) and it pulls like a bandit. Both of these props are pretty noisy from the ground at the lower pitch settings. At high rpm it almost sounds like a constant speed prop. Couple guys around here are waiting for the 0320 STC.
    Thanks KevinJ, Steve Pierce thanked for this post
    10,992
    supercrow's Avatar
    Dec 2008
    460
    I think so Pete. That price is the exp. or course. Mine was around $4000 with the spinner. If the prop hasn't changed for the STC I think that is the one.
    10,992
    That is about 1/3 the price and half the weight of the Whirl Wind 200G. https://www.whirlwindaviation.com/props/STOLGSeries.asp I really like my 200G and will not be changing.... But, 25 lbs. off the nose is a lot. I could likely take the lead out of the tail too.
    This new Sensenich is certainly worth looking at.
    Thanks Poor Joe thanked for this post
    Upper Peninsula of Michigan
    587
    https://www.avweb.com/aviation-news/...uper-cub-prop/
    Yup, This article says $6,350 to $7,085...Pricey, but good for them I guess. Gotta pay for all that STC Stuff somehow.
    Dec 2016
    Canyon, tx
    721
    Quote Originally Posted by EdH View Post
    Damn. That’s stings a bit. I get it. How many tens of thousands do they have getting the approval. Several.
    For the same money however you could have two McCattos. A fine and a course and enough money left to buy a bottle of top shelf McCormicks vodka
    Likes RaisedByWolves, Poor Joe liked this post
    May 2016
    Brenham, Texas
    52
    About how long does it take to change the pitch? And what tools are needed?
    supercrow's Avatar
    Dec 2008
    460
    If there is no spinner on it you need a torque wrench and a 9/16 and 5/8 socket. Loosen the bolts, put the pitch gauge in and rotate the blade against it. Same for other blade and re-torque. 10min tops. The whirlwind takes me about 20 min. Both are worth it for me. I can go from extra cruise speed to stump pulling grunt.
    Likes ross d liked this post
    May 2017
    834
    More like hundreds of thousands for an STC. It ain’t a cheap process!
    Rochester, NY
    147
    I am impressed with my Sensenich on an 0-235. 76” diameter. Easy to change the pitch. I will see how it performs on floats. Good I will bet.
    20,542
    Yea but I will be legal and make it to the STOL contest and be sitting in the Beer tent watching the girls and everyone get plastered while you are swapping that prop you carried in on your wing.
    Dec 2016
    Canyon, tx
    721
    Hehehe. What’s slower? Running fast prop and dragging slow prop in a box or just leaving the slow prop on?
    180TigerCub's Avatar
    Jun 2004
    Penn Yan, NY
    16
    I ordered one yesterday.
    Turnbull is squirming bad so I asked about the PA-12's. Sensenich has plans to complete other Piper models although they don't know when.
    This was the 1st approval using the Part 23 Regulations and it was challenging for both the Feds and Sensenich. They expect the next approvals to be smoother.
    Having completed STC's in the past, I give them huge kudos and big thank yous for this one!
    Happy to pay the extra to cover costs and make it a successful project.
    180HP PA-18
    Likes Steve Pierce, DENNY, AkPA/18, Colorguns liked this post
    10,992
    Quote Originally Posted by 180TigerCub View Post
    Interesting, I wonder why they used Part 23 to certify an installation on a Part 3 airplane? It used to be any alterations to a certified airplane would use the original certification regulations. Perhaps Part 36 for the noise requirements?
    Dec 2016
    Canyon, tx
    721
    I know you better than that. You won’t be in the beer tent. You’ll be walking around visiting!
    Likes RaisedByWolves, Steve Pierce liked this post
    RaisedByWolves's Avatar
    Feb 2005
    4,353
    You mean talking?
    20,542
    Yep, and waking you and Alaska Steve up way to early after your late night of fun.
    Dec 2016
    Canyon, tx
    721
    You mean talking?
    Yes. “Visiting” is Texican for talking. Enter the Arkanstol deal this fall and you’ll have an excuse to come down and visit with us.
