Results 1 to 8 of 8
Thread: Seal brake lines
    Dec 2019
    COLLEGE STATION, TX
    125
    Seal brake lines
    My brake lines exit through slots in two inspection covers in the floor of my fuselage. I assume this is typical. I get a good bit of exhaust fumes coming in around the brake lines. Anyone have a good trick for sealing around the lines?
    behindpropellers's Avatar
    NE Ohio
    6,933
    Quote Originally Posted by sdischer View Post
    I could make up some silicone seals for you if you would like.
    Wolf Lake, AK
    6,350
    Typical is a bulkhead fitting in a drilled hole. If you have lines through the covers and have room add a grommet. If no room cut a grommet and make a flange.
    mike mcs repair's Avatar
    11,773
    the problem is probably not the gaps up front there... but gaps in fabric at tail triangle creating a vacuum in fuselage.....
    Likes cub yellow liked this post
    Dec 2019
    COLLEGE STATION, TX
    125
    The triangle just above the tail spring on the bottom of the fuse isnít covered. Iím wondering if that one inch wide by three inch long gap is enough to pull a vacuum?
    11,773
    The triangle just above the tail spring on the bottom of the fuse isn’t covered. I’m wondering if that one inch wide by three inch long gap is enough to pull a vacuum?
    absolutely...
    we used to leave it uncovered on all jobs... till we figured out it was a problem CO wise....
    just stuff a piece of foam rubber in there to block it... and retest..
    Dec 2019
    COLLEGE STATION, TX
    125
    Thanks Mike. I will give that a try. All I have to do is crack the heater open and the smell stops. I think you are onto something.
    Dec 2019
    COLLEGE STATION, TX
    125
    SOLUTION: I have a saying, every problem is the result of a previous solution and this time it is no different. I raised my breather tube up a couple of inches a while back to get it out of the slipstream under the cowl as an experiment and that really reduced the oil on my belly and I was excited about that. What I didn't realize is this caused a bad smell in the cockpit. I have been chasing what I thought was an exhaust smell in the cockpit in this thread and as an experiment I dropped the tube back down and the smell disappeared. Completely. So, bottom line is the smell wasn't exhaust, it was crankcase vapor and I will have to live with the little bit of belly oil. I am only running 3 qts and I have the Aerobat elbow so short of an oil separator, I think I am at the best possible compromise and should just plan to buy rags.
  1. Nylo-Seal Tubing & Fittings for Fuel Lines
    By Jasperfield in forum Experimental Cubs
    Last Post: 09-21-2019, 07:21 AM
  2. Brake lines for a PA-12
    By Pundy in forum Super Cub Sick Bay
    Last Post: 05-16-2013, 10:57 PM
  3. What Thread Seal for Fuel Lines ?
    By 1953supercub in forum Tips and Tricks
    Last Post: 05-26-2005, 06:37 PM
