Results 1 to 27 of 27
Thread: How much does a 30 gallon belly tank weigh? Roughly..
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,204
    Trying to guess-ta-mate how much weigh would be shed by removing a belly tank and pump from a PA-18. Ball Park figure.
    Float and Tailwheel CFI,
    Dragonfly Aero
    Homer, Alaska
    dragonfly@alaska.net
    http://www.floatplanealaska.com
    or http://www.dragonflyaero.net
    White City, Oregon
    940
    32 pounds with hardware and pump
    Thanks Alex Clark thanked for this post
    Likes mike mcs repair, Alex Clark liked this post
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,397
    As weighed......
    Installed an Airglass LT32 fuel pod. Pod and mount hardware weighed 27.6. Fuel pump, lines, wires, fuses and switch added another 2.5 for a total of about 30 pounds. 30.1 to be exact
    Very Blessed.
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,204
    Thanks a bunch. I was guessing about 30 pounds but was not sure. Trying to brain-fart compute if an PA-18 that weighs 1345 pounds with 31s and a belly tank would leave me any usable legal on floats. Plus I would yank out the vacuum system, the DG, the artificial horizon and the KX155 with the glide scope,VOR head, plus an old ADF.
    Then install a Garmin G5 and a Becker lightweight radio. So between the tank, pump and panel stuff, maybe I could remove 45 to 50 pounds. Plus there is a metal headliner.
    Dragonfly Aero
    Homer, Alaska
    RaisedByWolves's Avatar
    Feb 2005
    4,352
    Metal headliner is good for 5lbs
    9,459
    sounds REALLY heavy. Must be more to the story, 180 hp with solid crank and Dakota wings?
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,204
    Nope. 160 horse, wide deck, droop tips , 3 inch extended gear. Old 31 inch Bush wheels, booster brakes, all the heavy panel stuff and a lot of old cables.
    I suspect the W&B is all messed up. The weights on the old float version are all make believe.
    Dragonfly Aero
    Homer, Alaska
    Feb 2005
    4,352
    Any chance getting it on scales before you buy and see where it’s at?
    Jul 2014
    Norman wells, NT
    81
    When I bought my plane I was a total newbie, it needed panel work and that's my one regret - like you said I should have gutted the vaccume system and steam gauges. My plane had the origional huge piper AI and HI, I went with small modern ones. That was before the G5 days but I could have just gone with the Dynon pocket panel even though its gps based. I did rip out the VOR and ADF though. Both were the huge box all in one style ones. The panel was so huge that the stick hit it when pushed forward so you know what the former owner did? Just cut the stick a few inches shorter
    Feb 2015
    Anchorage
    71
    Look at the Uavonix AV30 instead of a G5. Lighter, simpler, and more features.
    11,345
    Quote Originally Posted by md11freighter View Post
    I'll second, and third that suggestion. I installed two, got rid of the vacuum system, and if I were in a Cub, I'd install an AV-30 C front and center, and pull almost everything else out of the panel, except nav. No need for VSI, Slip/Skid ball, volt meter, etc, etc.
    I'm really impressed with the functionality, and these things weigh almost nothing. I think they're also a little cheaper than the G-5 and fit in a 3 1/8 hole with no modification. In a no gyro cub, one of these things could save your neck in weather.
    I've really, really wished I'd had something like this more than once.
    On the original topic, however, that weight doesn't sound that unrealistic on those tires. It may still have a generator, heavy starter, brass oil cooler, etc, etc. too. Now you're starting to talk big bucks to lighten, though replacing those with lightweight stuff can reduce weight ~ 40 pounds.
    If that weight is accurate, unless you install the 2000 pound gross weight kit, forget using it as a seaplane trainer. In fact, depending on the size of your DPE, it may in fact be really tough to get MOST Super Cubs light enough on floats to do training.
    You already know this, but when you're doing float ratings, a lot of your customers show up and you instantly start doing mental math. I sold my Super Cub and bought a 170 for that very reason. My Cub wasn't that heavy, but with a GW of 1756 there was just no way that plane could be legal, and our DPE wasn't exactly "petite" either....
    11,345
    Just as an example,
    Consider a hypothetical Super Cub, on floats.....starting with a 1200 pound Cub, exchange weight of EDO 2000 floats is ~ 170 pounds. Now, your Cub weighs 1370. Add at least 20 gallons of fuel, for 120 pounds, now you have a basic weight of 1490 pounds. Then there's survival gear. Let's say you can get that down to 20 pounds.....now you're at 1510.
    Super Cub gross weight on floats is 1760 pounds. So, your useful load is 250 pounds.
    Are you seriously going to use this airplane for certifying new seaplane pilots? I've had a number of seaplane students who weighed more than that by themselves.
    Okay, let's say you find a SC that weighs 1100 pounds on wheels, honestly...(good luck there). That gives you a useful load of 350 pounds once the floats are installed, and gas. How much do you, the instructor weigh? Let's say you weigh the FAA "average" of 180. Your students can not weigh more than 170 pounds???
    And, again, what's your DPE weigh? Is your DPE going to conduct checkrides in an over gross weight condition, like every checkride? I can show you a guy who got bit doing that. Trust me, you don't want to build a business model on that concept.
    So, are my calculations in error?
    Bottom line: If you're going to use a Super Cub for seaplane training, you NEED the 2000 pound gross weight kit. The good news is, that kit is now applicable to EDO 2000 floats. The bad news is....well you already know that.
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,397
    Alex
    If it is on 31's with extended gear and has the usual 3200 TW your gear weighs 125 pounds. So if Edo 2000's weigh 251 then your exchange weight is 126 pds
    Very Blessed.
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,204
    That was the beauty of the non-electric PA-11s on floats. 1350 gross on floats.
    I would unload the survival gear and all but 8 gallons of gas. ( only burned 4.5 gallons an hour.)
    My DPE back then claimed he weighed 200 pounds.
    After the check-ride we would fuel up, reload and fly home.
    I gotta find out what the one ton stc costs.
    Dragonfly Aero
    Homer, Alaska
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,204
    Looks like the Uavonix AV30 is about $300 to $400 less than the G5, ( I put two G5s into my 180 a couple years ago.)
    The AV30s weigh 0.50 pound each.
    The G5s weigh 0.96 pound each
    Interesting,
    Dragonfly Aero
    Homer, Alaska
    10,992
    Quote Originally Posted by Bill Rusk View Post
    Alex
    That number is a salesman's number.
    The weight of EDO 2000s from EDO's official affidavit of the weight and balance is as follows:
    For a PA-12.. 265 lbs. @ 14.2"
    For a PA-18.. 263 lbs. @ 14.0"
    The speed fairings add 4 lbs. to the above weights.
    Thanks Bill Rusk, Alex Clark thanked for this post
    supercrow's Avatar
    Dec 2008
    460
    My floats with 2 water rudders 2 hatch kits with floorboards with the bolts in the top fittings weigh exactly 300lbs. with no fairings.
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,204
    Wow! The PK-2300s I had on a late model 172 weighed 305 pounds. Yours are heavy...
    Dragonfly Aero
    Homer, Alaska
    10,992
    He forgot to pump them out before he put them on the scale. Either that or he used a grocer's scale. The one with the thumb on it.
    Feb 2005
    4,352
    My anfibs don’t weigh that much. At least that’s what the book says. Weird the actual weight was 200lbs heavier than what the book said. Guess we will use book weight.
    Amy's Avatar
    Jul 2009
    WI/MN/SD
    728
    $4,000 for the kit and all paperwork, plus USPS Priority Mail to Alaska is usually $30-$35.
    —Amy
    Proud owner of a collection of airplane pieces (sometimes in one big piece) known as the Oklahoma Kid.
    11,345
    My PeeKay B-2300s were close to that weight, but I think they were just a bit under 300.
    But, the B's are longer than the 2300s.
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,204
    PK-2300 on C172N = 301 pounds
    PK-2300 (B)s on C-172N = 305 pounds.
    Probably few few pounds lighter on a C-170B
    Dragonfly Aero
    Homer, Alaska
    FdxLou's Avatar
    Apr 2004
    1,856
    Amy
    The way the post office performed this Christmas I would use FedEx!
    Lou
    QUOTE=Amy;794062]$4,000 for the kit and all paperwork, plus USPS Priority Mail to Alaska is usually $30-$35.
    —Amy
    Sent from my iPhone using Tapatalk[/QUOTE]
    Amy's Avatar
    Jul 2009
    WI/MN/SD
    728
    Quote Originally Posted by FdxLou View Post
    Amy
    Lou
    —Amy
    [/QUOTE]
    Lou,
    You’ll be pleased to know in the lower 48 we are practically exclusively a FedEx operation (only brown if requested, and big stuff gets quoted to some specialty freight folks)! Non-USPS rates for a 2,000 kit to Alaska are usually more than double and USPS is often requested, but I’ll ship using whatever the customer wants
    —Amy
    Sep 2002
    Southern NH
    814
    Amy
    Lou
    —Amy
    [/QUOTE]
    One of my favorite stories... The major corporation I flew for had to send some important paperwork to one of their largest customers, UPS. Guess how the poor executive assistant sent it?? Yep, FedEx..... Needless to say, the delivery driver had a huge grin on his face when he pulled up to the building. UPS refused to accept it.. return to sender....
    Likes DavePA11, alaskadrifter liked this post
    Feb 2005
    4,352
    Quote Originally Posted by supercrow View Post
    48lbs more for anfibs isn’t bad huh
  1. FS: 90 Gallon Sorenson Belly Tank & Fairing
    By Hercubness in forum Parts and Pieces
    Last Post: 04-15-2020, 12:21 PM
