Navalav8tor
Looking for recommendations on metal Prop combinations on a PA-11 C85-12, thanks in advance.
Glenn, mostly climb. Hopefully that will allow me to continue to fly during our summer months in Texas...
Are you stroking the engine? that will make a huge difference in your performance.
I’m a new owner of a PA-18-95 that has a C90-12 and came with two props. One is a Mac 71-46 cruise prop and the other is a Sen 76-2-42 climb prop. The Sen is new with only 100hrs. The Mac is fresh overhauled. I’m going to be flying a bit with both of them to decide which I prefer and then will likely part with one or the other. PM me or text me at 641-529-0420 if any interest.
What basis are you going to use to install the 76 inch prop? Or are you experimental?
-2 means it was cut 2" shorter after being factory made
Almost, It was the factory which made it a 74. The 76 is the basic length of the design. The dash number is the amount the factory reduces the diameter from the basic design.-2 means it was cut 2" shorter after being factory made
