I’ve got my first plane. Pa-18a with a 150 in it. Currently running a 80/44. Id like to go to something with a bit more off the ground performance. At 5k each it doesn’t seem like a guy can test fly many props. Could someone explain to me their thoughts of the optimum pitch/length.
so far I’ve got recommendations for 82/43 and 82/41. From guys that fly the same as I would. Heavy most the time, nothing real high altitude, short strips, hops of a 100miles would be my long hauls. Some say the 150 won’t sping the 43 like it should be. Others say the 43 will save you in a bad situation when you need power now. Then guys say the 41 is the best for short field work just loose five mph or so.
thoughts?
thoughts?
