The 26 Goodyears are actually fairly low pressure when used on light planes like a J3. Mine were run at between 4 and 6psi in most instances which was a startling revelation when I finally got a low pressure gauge and checked them. After taking them off however it was found the tire had slipped a little on the rim although not enough to damage the valve stem. Keep in mind this is with double pucks but only the stock diaphragm brake master cylinders so not a tremendous amount of braking power.
They were surprisingly soft at that pressure and did fairly well considering the nature of the goodyear tires. Not nearly as nice or safe as a set of actual Bushwheel/Airstreaks however. The real telling thing about the Goodyears is how bent the gear bolts are. You can get away with them and do okay but the airframe is what takes the beating.
