I currently have a set of Landes 2500s rigged specifically for my -18 with 3 inch extended gear. One of the bungees is shot, so I’ve decided to go with atlee springs.
I’m sitting here thinking of the easiest way of doing this and the atlee spring requires 3 inches of tension, so all I should have to do is remove the bungee and cable attached to bungee, and then just redo this single cable to make sure there’s 3 inches of spring tension. I shouldn’t have to re-rig the entire ski should I? The check cables have obviously already been set, so it’s a moot issue I would think.
I of course like to overthink things. I have no problem re-rigging the whole thing but don’t see the point, so correct me if I’m wrong.
thanks in advance everyone
