Results 1 to 30 of 30
Thread: Cub Jigs
    nesincg's Avatar
    Jan 2006
    Chattanooga, TN (KAPT)
    631
    Cub Jigs
    I'm looking for a SuperCub fuselage jig anywhere in the southeast. For a friend. 71H is just fine.
    Sure would be nice to have an interactive map of jigs for those who want correct repairs. I'll settle for a current thread of all known jigs. Fire away.
    The aviator formally known as 89.
    Thanks Coondog thanked for this post
    mike mcs repair's Avatar
    11,773
    jigs, are nice, and a fast way to do things, pretty closely.....
    but if you have good and properly trammed wings installed, you can just measure back to tail spring attach bolt and do BETTER than most jigs around..(much better than Piper did...)...
    Thanks barrow pilot, AKlindy thanked for this post
    supercrow's Avatar
    Dec 2008
    547
    Yup. From what I have seen, the Pipers ones weren't special.
    21,305
    Talk to Tim about the guy in TN. I prefer repairing in my jig and all the sub jigs we have built over the years. Makes things easier, quicker and more repeatable results. Sorry I don't know of any in your area. To quote Tim "get your credit card out and call Univair".
    Thanks chuckwagon thanked for this post
    May 2020
    10
    I have one that is in maine if anyone needs one in the north east.
    Thanks supercrow thanked for this post
    Likes JP liked this post
    nesincg's Avatar
    Jan 2006
    631
    Quote Originally Posted by old guy 46 View Post
    Woohoo. Thanks for the post. I miss Maine, some days. That's two in the whole country.
    Feb 2004
    Mt.
    1,344
    Mike there is not much you ever say that I don’t completely agree with on here but measuring back from wings tells you nothing about AOI built into the fuselage which is everything that makes a cub fly like a cub. Even more important than having the correct AOI is having the SAME AOI on both sides. Cubs with much difference have Nasty Stall/Spin characteristics and will try hard to kill you..I learned to fly In one and it was always ready to bite hard. S2D and I did a bunch of turns and several thousand feet trying to recover, fixed the AOI and it became a real performer that the Grand Father of SC.org has proudly called his own for many years.
    dave
    Likes nesincg liked this post
    11,773
    Quote Originally Posted by ag-pilot View Post
    ..Even more important than having the correct AOI is having the SAME AOI on both sides..
    not true at all...
    even the jig that i used that was made from a never flown surplus piper fuselage was 1/2 degree different at root, 1" different from rear wing attach to tailwheel bolt(Airframes has this jig now, the yellow one out of Homer)
    and over 1 degree at wing root is VERY common on flying cubs...(you just split the difference when determining level flight)
    and add to that the difference between a real piper rear spar attach height & a unavair one seems to be just over 1/8" different height....
    from rear wing strut attach to tail bolt 1" difference is normal(jig mentioned above made from unflown piper fuselage)
    but on this field I know of one that's 5" different .... they won't go slow well like that... but ... It's been a working hunting cub for decades....
    Likes DENNY liked this post
    supercrow's Avatar
    Dec 2008
    547
    A month or so ago we rigged one here for an owner who said that it had a very heavy wing. It turned out to be about 1deg. different on the two sides of the fuselage. It is an older exp. and I don't know much of the 40 yr. old history. After making some strut adjustments, the owner says it flies very well and he is happy with it. Doing measurements on this one would drive you crazy but the end result is that is flies like every other cub that is set up to fly well. I haven't flown it myself and can't speak to the stall characteristics. I don't think this fuselage is any different than a lot of factory or hand built fuselages. They seem to vary greatly. Mine was hand built in a very good jig and it showed when we rigged it and flew it. A higher time pilot than myself flew it 25 hrs. last winter and said it was the straightest flying one he has flown. It is a pleasure to fly a straight and well balanced heavier s. cub that feels more like a J-3 or PA-11.
    Thanks 2cubfamily thanked for this post
    Likes LMartin liked this post
    21,305
    I have measured more Super Cubs than I care to think about. I have rebuilt 5 that had never been apart. I also have a mid 1970s surplus fuselage that still has the build number and part number written in red crayon on the front tubes. Piper built them all over the place. I have seen some with lots of incidence, not much incidence and lots of variation between the left and the right. My jig got built off a frame that Wayne Mackey did and it measured out very well and everything that has come out of it has flown very well. I figured out to measure everything, install the tail, measure the stab up and down and the elevator throws before blast and prime. Several that were never wrecked or repaired didn't meet the TCDS. I want all it says and if it says +/-5 I want all of that 5. My personal feeling is that a fuselage is only as good as the jig it came out of or the attention to detail the person put into getting all the angles correct. We have figured out what flies nice and that has been a game changer.
    May 2020
    10
    My jig was built off a new Univar fuselage.
    21,305
    1982 that was not wrecked.
    Left rear wing attach.
    Right rear wing attach.
    Lower right firewall.
    I have lots of pictures of stuff we have found, these were just quick and easy to post.
    Likes ak49flyer, DENNY liked this post
    21,305
    I installed a new Univair frame in my jig several years ago and it fit good, the rear wing attach fittings were a little higher than mine.
    Where are you located? Are you repairing fuselages?
    supercrow's Avatar
    Dec 2008
    547
    And it works very well, thank you.
    RaisedByWolves's Avatar
    Feb 2005
    4,533
    Looks about like mine did when it went in.
    Feb 2005
    4,533
    Steve didn’t you have a Univair that didn’t fit well in the jig?
    21,305
    The fuselage was a little high
    supercrow's Avatar
    Dec 2008
    547
    Steve, that is the jig that my fuselage was built in and it came out very well. He has repaired and rebuilt quite a number of fuselages over the years. Can do J-3, 18 or 12. Milo, Maine.
    Likes Steve Pierce, JP, mike mcs repair liked this post
    JP's Avatar
    Mar 2003
    The Big Woods of Maine
    3,302
    Mine came out of Milo. It's a keeper.
    JP Russell--The Cub Therapist
    1947 PA-11 Cub Special
    10,869
    Quote Originally Posted by nesincg View Post
    Mike Pynne? New life restoration in Tenn. Paul Babcock uses him for fuselage repair
    Likes FLYERKODI liked this post
    nesincg's Avatar
    Jan 2006
    631
    I'm considering making one from a good fuselage. Put it on a trailer as a builders resource. Can people post pictures of how theirs are built? This is the one I'm all to familiar with.
    Thanks Trimcable thanked for this post
    Feb 2004
    Mt.
    1,344
    So you have a fuselage that measures 1 degree on the left and the max allowable 2 degrees on the right...this is from the horizontal reference to the bottom of the wing which is about the only easy way to measure a flying airplane without taking it apart.if you rig both wings by the book it will fly left wing heavy all else being equal. So now you have a choice on how to make it fly hands off, take some twist “washout” out of the left wing to give it more lift or put more washout in the right to give it less lift.
    The problem is that the wings rigged to fly hands off on a bad fuselage stall differently,the one with less AOI and less washout will stall more completely end to end and the right side which is making more lift at the butt and a lot less at the tip will usually but not always stall first. This scenario makes normal spin recovery null and void and you now a unpaid test pilot. I learned to fly in such a beast and was scared witless more than once at low altitude by its extremely poor manners
    steve p is exactly right even factory built never damaged airplanes are off and can be made to fly/perform better with a good jig and someone that knows what to look for.
    dave
    Dec 2014
    32
    I have a forward fuselage jig that also jigs a zero degree engine mount. Built from drawings, very accurate. Located in British Columbia, Canada. About 3’ X 6’ X 8’, 100 lbs. Free to good home!
    Kevin.
    (250)466-0927
    Feb 2021
    2
    PM sent
    May 2017
    1,167
    Something else to consider, every time you heat a cluster to red, the tubes shrink almost 1/16”. It is surprising how much that 1/16” change can do especially if the same cluster has been repaired a number of times.
    3,899
    Maybe. Depends on the cold stress. If in tension or neutral, yes, it will pull. If in compression, maybe just relax the joint.
    Southern Aero's Avatar
    Jan 2008
    kcco/1ga2
    237
    But there are ways to mitigate that.............................................
    Dec 2014
    32
    Jack leg….do you still want the fuselage jig? Give me a ring(250)466-0927
    cheers Kevin
    Feb 2021
    2
    Still interested, will call tomorrow when I'm in cell service.
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    394
    what do you think about Alaska air frames fuselages
  1. supercub fuselage jigs
    By fobjob in forum Super Cub Repair Facilities
    Last Post: 09-27-2003, 01:13 AM
  2. fuselage jigs
    By Arturo in forum Tips and Tricks
    Last Post: 08-04-2003, 10:47 AM
