Results 1 to 5 of 5
Thread: I increased my oil pressure
    Dec 2019
    COLLEGE STATION, TX
    117
    My C90 has always run about 32 psi oil pressure. That’s the bottom of the green arc but never goes below so ok. Today in my relentless pursuit to fix every oil leak in the world I dropped the oil sump tank to replace the gasket and while I had it off I did a little inspection. I found the oil suction tube was a little wiggly. It was safetied it as it should be but just slightly loose. I turned it may be a 16th of a turn to where it should be tight and I rewired it. I put everything back together and cranked the engine to check for leaks and guess what, more oil pressure! It now runs 42 psi cold with Aeroshell W100 and 40 at cruise when at operating temperature. That little bit of air leaking on the suction tube threads was costing 8 psi oil pressure. Something to keep in mind for the future.
    Thanks silflexer, Farmboy, Speedo thanked for this post
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,017
    Good job. You should say "I upped my oil pressure, now up yours."
    Likes mike mcs repair, windy, sdischer liked this post
    nd
    3,714
    when i did my motor i did a copper gasket there and not the crush type, i gotta look in the parts book again and see what is actually called for. that tube shakes and vibrates quite a bit.
    nd
    3,714
    Dec 2019
    COLLEGE STATION, TX
    117
    Useful info thanks!
  1. W&B question with Borer increased GW
    By jadebons in forum Piper: PA-12 Super Cruiser
    Last Post: 01-09-2019, 09:26 AM
  2. Has anyone increased AOI on a PA14, PA12, Wag 2+2, etc?
    By RVBottomly in forum Experimental Cubs
    Last Post: 12-19-2017, 03:02 PM
  3. Pa-12 increased gross weight questions.
    By ChickenCub in forum Cafe Supercub
    Last Post: 10-27-2015, 01:48 PM
  4. Increased fuel consumption
    By SimonK in forum Sportsman's Den
    Last Post: 08-13-2006, 11:36 PM
Tags for this Thread
