Results 1 to 20 of 20
Thread: Ice screws.
    Wolf Lake, AK
    5,809
    Ice screws.
    Because it's winter and some guys may need some. This is a good price!
    https://www.backcountry.com/black-di...SABEgLI6_D_BwE
    Thanks jrussl, rmac thanked for this post
    Likes DENNY liked this post
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,449
    dont be cheap
    buy the style of screws with the little hand crank on em. So much quicker to set!!
    Wolf Lake, AK
    5,809
    Snap a carabiner on it and it makes a great handle. Not ideal for an ice climber but it works great for my use.
    The reason I found those is because I want to buy some screws to test lateral and diagonal pull strength. I want to know how much pull it takes to have the tie arm fail. Those Black Diamond screws are what I've carried in my winter gear for 20 years. I'd like to know what they can take. One plus for those screws over the more expensive ones is they're carbon steel, not aluminum.
    Feb 2009
    67.8N,115.1W CYCO Canada
    935
    Almost twenty years ago the Russians were dumping a lot of titanium on the market. I bought three titanium ice screws with carbide tips - very light and (I think) quite strong.
    I just wish that I had bought a set of titanium cooking pots when they were available at a reasonable price!
    10,407
    Quote Originally Posted by NunavutPA-12 View Post
    Lots of both on ebay
    Thanks NunavutPA-12 thanked for this post
    Paul Jackson's Avatar
    May 2011
    216
    So these strong enough for a 180?
    Wolf Lake, AK
    5,809
    To tie one down? Depends on ice composition and how much wind. My 180 probably never sees higher than 40mph when tied to screws but I've never had one loosen.
    Aug 2002
    Talkeetna Alaska
    281
    Think about it. A Cessna wing will lift GW at not very high speed. If it is windy, you will need a pretty hefty tie down if pointed upwind and the wing is clean. A friend of mine tied his 180 to two snow machines on a windy night and later noticed it was lifting both machines off the ice. Luckily they changed the setup before any damage.
    Ice screws are handy but tricky. They will melt out under the right conditions and will pull out under enough vertical tension.
    Thanks Bowie thanked for this post
    2,611
    Ropes to the ice screws need to be angled towards the wind. That creates an initial shear force on them vs vertical load on their threads. And gusts can create pressure on the screws which melts adjacent ice. They will walk away from the gust direction so put them in top angled slightly towards the wind to begin with. I also like one on the tail and one to the landing gear to prevent aircraft creep back. Plus spoiler wing covers and a martini for sleep.
    Thanks 40m, C130jake thanked for this post
    Likes 40m, JP liked this post
    Wolf Lake, AK
    5,809
    And that's why I'm motivated to test them. Ice screws are designed for sheer loads but we use them primarily in tension. I suspect the clip arm will fail and separate before a screw pulls out of good ice. In my use I'm trying to keep my plane from sliding in the wind. If I'm hoping to overcome lift I'm using the wrong tool. I have tied snowmachines and heavy sleds to my plane to supplement the screws overnight but that's rarely necessary.
    My 180 sits nicely in winds that would blow my Cub away. Paul asked if ice screws are enough for a 180. My question is are they enough for my Cub. If I parked the Cub in a 30mph wind with scope in the lines to the upwind? The plane would increase AOA and try to fly. I need this plane pinned firmly to the ground with no scope that will allow AOA in increase. The screws will be in tension and I'd like to know what the fail load is. I have screws, a lake, and a tractor to test with. I just need to figure out a shield to protect me when the screw fails and the line backlashes.
    Likes 46 Cub liked this post
    Feb 2008
    Juneau, AK
    142
    Here is a pretty comprehensive summary of drop tests on ice screws:
    https://mra.org/wp-content/uploads/2...rews_Final.pdf
    Essentially the angle should be ~20 degrees towards the force, and in good ice should expect to hold up to 10kN (~2,250 lbs).
    Thanks stewartb, BC12D-4-85, tedwaltman1 thanked for this post
    Likes jrussl liked this post
    Dec 2018
    Rangely, Co
    40
    Stewartb, might I suggest draping something cloth (blanket for example) over the line about half way towards the screw in your pull test. Actually anything you can tie to the rope will help absorb the energy when the ‘release’ occurs. I’ve seen a winch line ‘release’ while winching a vehicle, and this really helps dissipate the energy and slow the projectile.
    Likes akmarty liked this post
    Wolf Lake, AK
    5,809
    I always drape a canvas tarp on ling winch lines. This will be a short line with a chunk of steel on the end. The line won't be what fails. New territory for me.
    Dec 2018
    Rangely, Co
    40
    Do you think the attachment loop will fail? Just another chunk of line also attached to the loop would work. Just thinking out loud. Anything to slow that thing down.
    Wolf Lake, AK
    5,809
    I "think" the attach arm will fail before the screw releases but I may be wrong. If the screw comes out the projectile is much more dangerous. Right now we have clear, hard ice so I should get a good bite. I want to know how these things will fail in an application they're not designed for. Maybe this weekend.
    Likes Kid Durango, akavidflyer, BC12D-4-85 liked this post
    labrador_cub's Avatar
    Jul 2016
    Wabush,NL
    95
    stewart are you doing this with a tractor that has a front end loader? if so weld a lug to the inside of the bucket and while pulling keep the bucket in a position that when the fail happens the line and whatever comes with it recoils back into the bucket. most people have a lug on the top edge for pulling (I'm guilty of this, haven't gotten around to adding the internal lugs yet on my equipment) and when stuff breaks the line wips back and up towards the cab as you most likely already know. if your hauling from the back using a 3 point hitch to pull up, I'd stick a piece of plywood between me and the back of the seat and hope for best. a heavy steel cable rated for much more then the force you plan that wont stretch and store energy should make things less climatic to.
    Wolf Lake, AK
    5,809
    Good suggestions. Thank you! I have a loader and a hoe. I'll see if I can finesse the levers well enough for the scale to read accurately.
    Jan 2005
    Fowler, Ks
    607
    What about attaching another line loosely on the screw and anchored to arrest the screw when it fails?
    Dec 2018
    Rangely, Co
    40
    Stewartb, did you get a chance to do some testing?
    Wolf Lake, AK
    5,809
    No, the weather changed to mid-40s for a couple of days so I'm waiting for colder weather and better ice.
    Thanks Kid Durango thanked for this post
  1. screws
    By tkj in forum Experimental Cubs
    Last Post: 06-13-2012, 09:29 PM
  2. Shakeproof Screws..?!?
    By BES in forum Super Cub Sick Bay
    Last Post: 06-25-2007, 10:52 AM
  3. Loose Screws
    By RON NORMARK in forum Super Cub Sick Bay
    Last Post: 06-01-2006, 12:15 AM
