Thanks Thanks:  0
Results 1 to 6 of 6
Thread: Tank straps that are lightened?
    Sep 2015
    Near the arctic circle
    10
    I was checking out a video of the AK Airmens raffle plane being built by Acme. In the wing build video there is a tank strap that looks like plumbers tape with holes the whole length. Is this a different part number or an aftermarket part? Is it save weight? Where is it available?
    https://www.youtube.com/watch?v=GSc1g-Bvo2w
Name:	Screenshot_2020-11-20 Alaska Airmen's Association.jpg
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    249
    I would assume it is to save weight. Knowing Steve he probably just put them on the drill press and drilled holes. Doesn't look to be very evenly or perfectly spaced holes but it gets the job done.
    Rob's Avatar
    Nov 2002
    AZ06
    783
    One of the most common ways to end a cub crash sequence is upside down. While I realize that there are many potentials for a tank to depart rupturing fuel lines, adding one more to the list doesn't strike me as an overly wise choice.
    I'll leave my belt buckle on the dresser if it gets that tight.
    Take care, Rob
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    249
    But what if you left your belt buckle and ​drilled out your tank straps? Now we're talking real weight savings!
    S2D's Avatar
    May 2002
    Montana
    4,250
    Quote Originally Posted by Rob View Post
    I was just wondering this morning before I saw your post, if this is even legal. I would consider these straps structural.
    What are 20 years of rough field landing going to do to those straps??
    10,630
    Those straps appear wider than the normal strap. Does he have a reason for that? The strap is only as strong as the total amount of the materiel on each side of the biggest hole. SO, making a strap as wide as the total of those two dimensions without holes would have the same strength. The difference would be in the distribution of the forces into the tank itself.
  1. WTB Left Hand PA-18 or PA-11 Fuel Tank, straps, tank cover
    By supercub in forum Parts and Pieces
    Last Post: 01-21-2019, 12:10 PM
  2. Fuel tank straps
    By chinook in forum Experimental Cubs
    Last Post: 01-21-2018, 06:22 AM
  3. PA-12 Tank Straps
    By KJC in forum Cafe Supercub
    Last Post: 03-24-2008, 03:00 PM
