Thanks Thanks:  0
Results 1 to 5 of 5
Thread: tach seal
    Jan 2017
    Utah/Alaska
    184
    tach seal
    Does anyone have any tricks to replacing the lycoming tach seal? I need to do one and I see that spruce carries a tool but I am unsure of how well it will work. Tim
    Apr 2008
    Vic Australia
    43
    Haven't done one for a while but shouldn't be too difficult. Not sure what the tool is to remove them insitu. Use a couple of picks to pry the old seal out. Dont damage the housing. Lube the shaft then tap the new seal in gently using a socket or sleeve etc.
    Should work a treat.
    Likes boarfish liked this post
    Apr 2015
    Platinum
    274
    I’ve used a close quarters right angle drill with a short number 40 drill bit..drilled two holes into the seal, screwed in a couple number 6 sheet metal screws then slipped a short tiny torx head bit into the end of the tack drive shaft to pry against using 1/4” key stock as the lever.
    11,491
    buy a tach drive cover w/seal.... and put in an electronic tach?
    https://www.aircraftspruce.com/catal...es/tachcap.php
    Jan 2017
    Utah/Alaska
    184
    I wish but the owner wants to keep his original tach...
  1. New tach
    By i-fly-low in forum Cafe Supercub
    Last Post: 06-30-2013, 06:23 PM
  2. Need help with tach wiring
    Last Post: 03-15-2013, 01:55 AM
  3. Need a new Tach
    By skukum12 in forum Modifications
    Last Post: 07-23-2012, 08:58 AM
  4. Wacky tach
    By NimpoCub in forum Super Cub Sick Bay
    Last Post: 01-02-2012, 12:49 PM
  5. tach cable C85-8F to C90-12F or O-200
    By JimC in forum Modifications
    Last Post: 04-03-2007, 10:15 PM
