Results 1 to 16 of 16
Thread: Borer 80" for O-320-B2B
    Jun 2020
    8
    Hey all,
    I'm looking to see if anyone has an 80 inch Borer for my PA-18 with a 160hp O-320 for sale.
    I'm located in California with cash in hand.
    Thank you and Happy Landings,
    Matt
    KIYK, CA
    RaisedByWolves's Avatar
    Feb 2005
    4,532
    I have one on my wall as a spare, I might be able to be convinced to sell it
    21,305
    Why 80"? The STC allows 82" and more is better.
    Thanks s09.mmcdonald thanked for this post
    Jun 2020
    8
    Steve,
    Thanks I don't know why I said 80 vice 82. For a 160, I'm hearing 43 pitch is best. Thoughts?
    Sent from my SM-G930V using SuperCub.Org mobile app
    2,516
    82/43 is what all the cool pilots run.
    May 2013
    67
    What is the difference in performance with the 82/43 compared with the 82/44? Why do some go with the 82/44?
    2,516
    Speed wise it is about 2 1/2 - 3 mph per inch of pitch. So a 44 is going to be faster than a 43 at 2400 RPM. It does not sound like a lot but if you have 2-3 hours one way to the hunting spot it all adds up A 43 will will get you off the ground a bit sooner, however a lot of that is pilot dependent. If you mission is not short and heavy go with the 44.
    Dec 2016
    Canyon, tx
    881
    Denny is right however sometimes the difference between hitting the middle of the tree or the top of the tree is a couple inches of pitch. I’ll take a 41 all day. Maybe a 40 if the tree is really big!
    Likes DENNY, mike mcs repair, Steve Pierce liked this post
    May 2013
    67
    Thanks. I have a 44 but I am still slow! Maybe 90 mph with the RPM at 2500, 160 horse. Goodyear 26, so not overly a speed drag and nothing else too draggy out there. Maybe I am a bit forward CG, seems to like to get off the ground better with 170 pounds in the back seat, go figure? A work in progress for me, thanks again for the ideas and inputs.
    Oh yeah, a big pod, I guess that takes a bit off the speed too of course.
    2,516
    Check the engine mount rubbers. Mine had a lot of sag at 1,000 hours. I gained 3 mph when I put in new ones. It is a thrust line issue.
    mike mcs repair's Avatar
    11,773
    Quote Originally Posted by Skysurfer View Post
    Bucket of state runway gravel in back when empty. Dump it at your remote strip. Then put in your load. That what my stepfather windy said Denny Thompson always did with his maule. Eventually he had a nice gravel runway...
    Likes KevinJ liked this post
    21,305
    I have a 160 hp and a 4182, it pulls good but will redline when I quit pulling on the stick. For my mission the lower pitch works best. Sure I'd like to go faster but have flown the same airplane with a 41 and a 43 I really never noticed a difference in cruise.
    May 2013
    67
    Denny,
    I will look into that, thanks. It has Thrustline.
    Thanks birch thanked for this post
    11,477
    Thanks. I have a 44 but I am still slow! Maybe 90 mph with the RPM at 2500, 160 horse. Goodyear 26, so not overly a speed drag and nothing else too draggy out there. Maybe I am a bit forward CG, (YES) seems to like to get off the ground better with 170 pounds in the back seat, go figure?
    As mike says: "Bucket of state runway gravel in back when empty." Or alternatively a smaller amount of permanent ballast at the tail.
    Airplanes with trimming stabilizers cruise faster, climb faster and fly slower when operating at or near their aft CG limit. This is because the stabilizer is unloaded, thereby reducing it's drag and reducing the added perceived load which the wings must carry.
    If you are a heavy person, it is very likely your plane is loaded at or forward of the forward CG limit when flying solo.
    May 2013
    67
    200 lbs. The difference withweight in back is an eye opener. I like the gravel idea. Thanks.
    11,477
    200 lbs. The difference with weight in back is an eye opener. I like the gravel idea. Thanks.
    Of course it's your option, you should be aware that it is not unusual for an airplane to have some permanent lead ballast as far aft as possible for just the reason you describe.
  1. WTB: Need a McCauley "Borer" PA-12
    By daedgerton in forum Parts and Pieces
    Last Post: 10-18-2019, 10:43 AM
  2. 82"Borer on PA12
    By C130jake in forum Float Operations
    Last Post: 01-25-2017, 01:16 PM
  3. What designates a "Borer" prop?
    By CptKelly in forum Modifications
    Last Post: 09-25-2004, 10:32 PM
Tags for this Thread
