Originally Posted by
stewartb
For consideration. In cool temps at altitudes I fly my 75% power RPM would be around 2500. Lycoming says to take off and climb at 100% power, level off and run it at 75% power for an hour, then an hour varying between 65-75% power, then 30 minutes at full power. 100% power is 2700 RPM. Breaking in with a constant speed I used similar RPM targets, adjusted up a little for warmer temperatures. Assuming the Borer doesn't exceed 2700 RPM in level flight, what's the problem?
