scottsville
HI, I just put new Steve's master cylinders on two cubs. One the brakes work unreal and with the same pressure the other one not so much. I noticed the brake pads were a bit different. The brakes that work the best, the pads look not as smooth surfaced as the other ones. More rough looking but smooth if that makes since. Is there different brake pads that grip better than others. And what is the best pads to get for the best braking possible?
Thanks!
Thanks!
