Results 1 to 15 of 15
Thread: Yellow Paint hues
    May 2017
    53
    Yellow Paint hues
    Hello SuperCubbers! My 1993 SuperCub has original yellow paint. In log book it’s listed as “Cub Yellow”, AirTech Polyurethane, yet I’ve seen a wide variety of “Cub Yellows”. Any advice on how to find a matching batch for touch up?
    11,738
    you CANT!!! yellow form the same can, will be a different color/shade each time you spray it... majorly different..... yellow sucks!
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    762
    Whatever you do paint it white first
    Likes Hardtailjohn, JeffP liked this post
    RaisedByWolves's Avatar
    Feb 2005
    4,280
    And if you get a run on one side of the boot cowl and re paint it will be a different color too
    Likes mam90, mike mcs repair liked this post
    Dec 2016
    Canyon, tx
    682
    Quote Originally Posted by Spad View Post
    Call Robbie Staton who owns Airtech. He will do his best to help you. He explained the process and the machine used to try and match colors the last time I was there. It’ll make you pull your hair out. I bet he can mix you something close enough that you can live with.
    20,374
    If you are just doing touch ups and the paint is that old I would take an inspection plate to a body shop or paint supply with a paint matching spectrograph. Probably a better match than getting the same color made today, the fade will not match the new out of the can yellow.
    Likes Scooter7779h, ak49flyer, Richgj3 liked this post
    2,233
    Wait, are you guys saying that all the different red and white colors on my plane should match???
    Thanks flyboyrv3 thanked for this post
    Likes Richgj3 liked this post
    7,329
    Yellow is a special problem - cannot use chromium. None of the current yellows match 1993 yellows.
    Randolph and Stits are the worst - they kept the same names, but changed the formulae.
    Early Stits Cub yellow is now closer to 140 orange yellow. Randolph swapped Sport and Lock Haven yellow.
    Stewarts Cub Yellow is closer to early Stits Cub yellow. And I agree - Airtech seems to match itself well. We just bought a gallon of Clark Yellow and it is almost a perfect match. Very expensive to get somebody else to spray it (I personally won't touch it) but drop-dead beautiful.
    And yes - spray insignia white first. Always. Even on small repairs.
    We did get some matching rattle cans for the Stearman - AN Yellow. Could not match it myself, no matter how hard I tried. Had lots of help with Norm Douthit - even a free can of burnt umber.
    20,374
    I quit worrying about the colors years ago and just put on silver.
    Likes tedwaltman1, DENNY, ak49flyer liked this post
    3,336
    Years ago, I walked into the brand new Cabela's in Lacey WA--
    there was a J3 Cub with Bushwheels hanging from the overhead in the foyer just inside the entrance.
    I stopped there & was checking it out, and the greeter at the door told me "that's a mock-up".
    I told him no, it wasn't, it was the real deal.
    He asked me how I knew,
    and I pointed out that it was painted about three different shades of yellow.
    Likes mike mcs repair, mam90, flybynite liked this post
    Jun 2020
    4
    Can you guys elaborate on spraying white first? I am going to be painting areas of that I repaired soon. I had a pint of Aerothane PF-140 Orange Yellow made up to match the paint job on my cub.
    Matt
    Vermont
    347
    When a paint claims "good hiding" it will look the same over different shades of primers and base coats. Yellow in general, regardless of mfg, does not hide well. I think whites tend to be loaded titanium dioxide, good hiding and generally brightens things up.
    What's a go-around?
    3,623
    Quote Originally Posted by s09.mmcdonald View Post
    Matt
    Any time you paint a bright color, put on a coat of white first. It keeps the top coat crisp and bright. If you spray a bright color over something like zinc chromate or even gray primer, it will look dark and muddy.
    RCharles's Avatar
    Jan 2004
    Atlanta, Ga
    255
    stits 140poly should never have been named military orange yellow cause it was not as orange as cub yellow.That caused lot of confusion I believe.
    Aug 2012
    In the woods
    762
    The base color really affects yellow. Yellow over gray looks greenish. Over white it's more true yellow.
    Likes mam90 liked this post
  1. FAA and yellow paint
    By bob turner in forum Cafe Supercub
    Last Post: 02-26-2017, 11:56 AM
  2. Cub yellow paint code #
    By cubmanky in forum Super Cub Repair Facilities
    Last Post: 09-15-2004, 10:11 AM
  3. Paint Codes for #143 Cub Yellow
    By C-YQK in forum Tips and Tricks
    Last Post: 02-17-2004, 05:53 PM
