Page 2 of 2 FirstFirst 12
Results 41 to 70 of 70
Thread: Oil analysis and sticking exhaust valve?
  1. #41
    G44's Avatar
    Oct 2011
    SW Michigan
    685
    Quote Originally Posted by mam90 View Post
    Everything the same Gary, except probably slightly more 100LL post overhaul due to the Alaska trip. Harder to find mogas enroute. Trusted engine shop said he suspected improperly ground seats. He said he never installs new cylinders anymore without checking as he’s seen way to many. If I have any more problems I’ll pull the cylinders and take them to him.
    Mark,
    Do you run TCP? Auto fuel?
    Kurt
  2. #42
    G44's Avatar
    Oct 2011
    SW Michigan
    685
    Quote Originally Posted by bcone1381 View Post
    I know there are folks who are not a fan of Mike Busch on this forum. The dude admits he is more of a data analyst. Points of random data exists. If we can organize the data, then we have information. If we read the information, we can gain knowledge and which leads to wisdom....or maybe leads to improved reliability of Lycoming engines. It seems to me like Engine Data analysis is Mikes strong suite. The facts below are his, not mine. Below is a synopsis of the data Mike shares in that video link in post 28 and this AOPA article
    https://www.aopa.org/news-and-media/...intance-valves
    -Cool running engines have more sticky valves than warmer running engines.
    -Valves stick due to buildup of deposits on the valve stem inside of the valve guide.
    -Laboratory chemical analysis by a petrochemist from Exxon has been performed on valve stems.
    -TEL is used as an octane booster in 100LL fuel requires a scavenging agent.
    -This lead scavenging agent that is added to help avoid fouled spark plugs.
    -A chemical reaction during the combustion event produces a byproduct of the scavenging agent called Lead OxiBromide.
    -The Lab analysis showed that Lead OxiBromide is primarily the source of the buildup on the stems of stuck valves.
    -Engine Monitor will show a rough running engine from a sticking valve to produce an EGT value that is not normal. As the engine warms and the stuck valve loosens, the EGT will indicate normal.
    -Lead Oxibromide that remains as a gas above temps of 1100F.
    -After the combustion event we want the Lead OxiBromide to remain gaseous (above 1100F) to pass harmlessly out the exhaust.
    -The hotter the temp, the faster the lead is scavenged.
    -A cooler surface will condense these gases and over time form hard deposits on surfaces they contact, like a valve stem of an open exhaust valve.
    -Sodium filled Lycoming valve stems run cooler than Continental valves and the chances of a stuck valve is more likely with them.
    --Mike thinks that the conventional wisdom that the carbon deposits on the valve stem inside the valve guide from oil contacting the hot stem and carbonizing the oil is wrong.
    What Mike says to do....
    -Since CHT is the best indicator for Valve stem temperature, keep the CHT's between 350F - 400F to avoid Lead Bromide buildup on your valve stems.
    -Lean aggressively on the ground and low power operations to keep combustion temps as high as possible.
    Attachment 52176
    Thanks for that info. Did he comment on TCP and if it was good or bad concerning valve sticking?
    Kurt
  3. #43
    nightflyer's Avatar
    Jan 2012
    Colleyville, TX
    103
    Quote Originally Posted by G44 View Post
    Kurt
    According to this article TCP does nothing for sticky valves.
    Attached Files Attached Files
  4. #44
    Sep 2002
    Southern NH
    848
    Mark,
    Kurt
    I run both auto and 100LL, depending on what I can get. I’ve never run any fuel additives, but now I am using mmo.
    Likes DENNY, dgapilot liked this post
  5. #45
    2,749
    The chemistry tutorial above is courtesy of CamGuard. Note the short time (as little as 15-20 hrs) they suggest additives become depleted and the nastiness begins. If so, why fly 50 hrs on an oil....unless you use their product?
  6. #46
    Wolf Lake, AK
    6,048
    Through the years one of the aviation writer voices I've trusted is Ben Visser. He continues to advocate the use of leaded fuel in aircraft engines but continues to use 25% leaded to unleaded as a blend recommendation for breaking an engine in and occasional addition of leaded fuel throughout the engine's life. His reasoning centers around valve recession and valve heat transfer. In my own airplane ownership history valve recession and erosion has occurred in my engines. Valve sticking has not.
    I see evidence of accumulated exhaust crud on my shocks and remove it regularly. I assume lead is a big component of this crud. I plan to blend in some unleaded fuel to see if I recognize a reduction in the exhaust deposits. I don't have the knowledge or tools to do any important testing to find my perfect fuel so I'll err to the lead-rich side with my 10:1 cylinders. I'm not focused on valve sticking. I want the best fuel for the entire engine.
    Likes mam90 liked this post
  7. #47
    Wolf Lake, AK
    6,048
    If valve sticking is the problem a little MMO in the oil may be useful. I've been told that's where it got it's start with airplanes. Subsequently an engine build shop owner told me a little MMO in the oil is the first thing a pilot should do for suspected morning sickness. It may not be a long term solution but it should buy time.
    I routinely added MMO into my bulk fuel tank until talking to Mr Camguard about airplane engines and additives. He told me (this was over 10 years ago) that the MMO formula changed somewhere around 2000 and now contains a chlorinated something something and that was bad news for rubber and synthetic rubber. He didn't give its use much merit and said now it could actually do more harm than good. Since my 180 has bladder tanks I took his comments to heart and stopped using MMO. I can't recognize any difference in my engines.
    MMO is primarily a mixture of mineral spirits (Stoddard solvent) and light oil with some other magic smells and colors added. In the lead scavenging discussion which of those components is providing the benefit? Mr Camguard suggested that if I believed MMO was helpful I could mix my own and leave out the bad stuff. FWIW Seafoam fuel treatment is a similar mineral spirits/oil product with isopropyl added. Anyone using that?
    Thanks mam90 thanked for this post
  8. #48
    Sep 2002
    Southern NH
    848
    I do run camguard. I used to read the threads about sticking valves and additives and be thankful I didn’t have to deal with that. Then, overhaul with all new parts including cylinders and here I am. Hard to accept that I ran for so long with zero issues, have changed nothing in how I operate and now seeing these problems. I’ll have to look into the MMO issue, thanks.
  9. #49
    May 2016
    Brenham, Texas
    53
    Great discussion! I thought, (maybe incorrectly) that engine start wasnít recommended under 40*f if you were running straight 100w. Wrong? I run the Phillips 20/50 w/Camgaurd and I use MMO in the gas and fly about 200hrs/yr. I did develop low comp on one cyl last year (50/80) from a leaking exhaust valve. The valve guide was replaced now all 4 are running 78/80 but donít believe that had anything to do with the oil. What about engine start at temps below 40*f?
  10. #50
    Dec 2009
    Michigan
    98
    Is it at all possible that these new cylinders are running cooler than the TCM cylinders? Better Baffling? Do you have an engine monitor?
  11. #51
    Sep 2002
    Southern NH
    848
    Yes, that’s one of our thoughts. We built new cowling and all new baffling when we hung the engine. No engine monitor but we are going to try and rig something up to check temps. Thanks for the input..
  12. #52
    Mauleguy's Avatar
    Aug 2002
    772
    Quote Originally Posted by Mauleguy View Post
    My two cents. I did a top overhaul on my engine and used the Phillips 20-50XC as recommended for break in by the cylinder company. The good thing about this is you can just keep running the Phillips after break in. At around 250 hours on the cylinders on a trip to Alaska I had a sticking valve out of Dease Lake. That will get your attention real quick! I came back and landed and looked things over but did not know what was going on since I had never experienced this before. I could not duplicate it and continued on. I got to Ultima Thule Lodge and had it happen again one morning. I told Paul about it and he said it sounds like a valve sticking and asked what engine oil I was using. He told me he only runs straight weight Aeroshell and told me to change oil. I continued fighting this sticking valve for another 100 hours thinking how could it be the oil and I had a few cases of oil to use. It seemed if I did a long through warm up I did not usually have a problem, then one day coming through the gorge on top and it started doing it after a flight back from Idaho and I decided this has got to be fixed. I switched oil to Aeroshell 100 plus and it never did it again. I will never use Phillips again.
    Ok in the interest of completely muddying the water on what I wrote a few days back (see above). I was talking to Loni Habersetzer today about engine oil, he flies for Paul Claus and his engines go to TBO and beyond. I was telling him my experience with Phillips and what Paul had told me about just using straight weight Aeroshell. He fired back that Ultima Thule Airplanes all run Phillips 20-50XC now and have for at least 6-7 years since Paul asked him (Loni) what engine oil he uses because he had no problems ever making TBO. I asked Loni if he has ever had a stuck valve he said no. I will continue with my use of straight weights but here is evidence that maybe just believing in something can make it better
    Thanks mam90, nightflyer, G44, Steve Pierce, pfm thanked for this post
    Likes jrussl, DENNY liked this post
  13. #53
    2,749
    Frequent flyers can use any oil. It's the unfrequent flyers that need some help.
    Thanks G44 thanked for this post
    Likes G44, Steve Pierce, Vlad liked this post
  14. #54
    Mauleguy's Avatar
    Aug 2002
    772
    Ok, is not flying the airplane 6 months a year as Ultima Thule does (when there season is over) consider as frequent or infrequently. They fly 6 months daily and then not at all for 6 months, airplanes are hangard.
  15. #55
    2,749
    Are the hangars heated in the off season? Edit: If they are heated above freezing find out what steps they take to reduce or prevent corrosion when sitting idle. Might be worth knowing.
    Thanks Pop Alexandra thanked for this post
    Likes jrussl, DENNY, skywagon8a liked this post
  16. #56
    2,332
    If you read all the posts it is a total crapshoot on what seems to work and what does not. Flying daily/weekly does seem to help for lifter/cam issues. Valve sticking is all over the board. I think one of the issues is what lean, hot, often to one person is not the same to another. Bottom line is when you notice a change even for a few seconds look into it. I do like all the information that people post because it actually has some science behind it!!
  17. #57
    2,749
    From what I've seen here and in other Forums, periodic borescoping and valve cover removal (with pics recorded over time) might help show a trend in valve condition and the buildup of visible deposits. I'm not an expert in either. I do know it's a good idea to have uniform valve to seat contact to dissipate valve heat, and valve to guide inspection (visual/wobble test) can detect deposits. Some of the valve stem blow-by deposits can coat the exposed valve and springs plus the inside of the adjacent valve cover. If it becomes apparent then maybe there's a problem to be addressed. We try to keep the costs down and add a prevention step but maybe this would be worth doing?
    Edit: I found this lengthy video on using a borescope in an aircraft application: https://www.youtube.com/watch?v=Dk5o4__0y-4 Guess i'll learn something tomorrow.
    Likes JWE liked this post
  18. #58
    Apr 2020
    7
    Indeed. It should be common practice and would significantly extend the life-span.
    ________________________________________________
    Alexandra from https://cianalytics.com/technology/dry-colorimetry
  19. #59
    Dec 2016
    Canyon, tx
    758
    Quote Originally Posted by nightflyer View Post
    Iím curious to see if anyone else has noticed a trend in their oil analysis and sticking exhaust valves. I would occasionally get a slight shutter during cruise ever since my trip to Idaho in May. I just thought the engine was digesting some water since I had pulled a small amount of water out of the fuel tank when I sumped it during preflight. I only pulled water out once though. I just did a trip to Utah last month and I was getting some morning sickness on the first start-up and that was the first time Iíd had any issues on start up. I was probably in denial but I attributed it to the high altitude and cold weather. I had a couple of more shutters on the last leg home and then the the valve finally stuck for good on the first start up after my trip when I went to warm up the oil for an oil change. I certainly learned some lessons with what a sticking exhaust valve feels like now. My oil analysis had been showing high chrome which initially we thought was because the engine sat for five years during restoration and had some corrosion but it got worse as I ran the engine. Iíve attached my latest oil analysis to see if anyone has any ideas if there were clues to my sticking valve from that. It was the number 3 cylinder on a O-320A2B 160hp. I use Phillips XC 20W50 with Camguard, and I donít used MMO in the fuel or oil. The engine was built in 1982, had 1600 hours on it, and was never overhauled. Itís now at LyCon getting getting itís long awaited overhaul. Donít be like me and let it get this far when you get morning sickness. Iím extremely fortunate that the valve decided to stick for good after I got home and not on my trip.
    After seeing the recent dyno numbers from Jasonís freshly overhauled, fire breathing post stuck valve engine Iím thinking I also need a stuck valve and bent pushrod
    Likes nightflyer liked this post
  20. #60
    nightflyer's Avatar
    Jan 2012
    Colleyville, TX
    103
    After seeing the recent dyno numbers from Jason’s freshly overhauled, fire breathing post stuck valve engine I’m thinking I also need a stuck valve and bent pushrod
    Likes Steve Pierce, ak49flyer, KevinJ, Skywalker liked this post
  21. #61
    Sep 2011
    66
    Why not follow Lycoming's guidance? They allow around 400 CHT and they have a 400hr valve inspection written in the maintenance manual, operators manual, and encase you missed it they also published it in a Si, and a mandatory SB, if I am not mistaken. Yet, how many of us educated owners bother with it? Worse yet, how many FAA shops know about it or provide the required "push" to educate the owners about it? I know, if I fly part 91 I don't have to, but in some things it is in our best interests. I think that may be the case here.
    larry
  22. #62
    nightflyer's Avatar
    Jan 2012
    Colleyville, TX
    103
    My engine came back from its overhaul at LyCon. They’re running a special deal if you get an overhaul in April, you get a free cat.
    Likes RaisedByWolves, hotrod180, RVBottomly liked this post
  23. #63
    20,643
    That is my Chief Inspector, you can't have Alley cat.
    Likes nightflyer, cubscout, windy liked this post
  24. #64
    Richgj3's Avatar
    Apr 2005
    LI,NY
    1,158
    Iíve got the cat. Canít find a new engine anywhere.
  25. #65
    Dec 2016
    Canyon, tx
    758
    Did your inspector catch the 10:1s and 340 crank?
  26. #66
    20,643
    Like I told Jason, FedEx lost his engine, the pictures are of my new engine. Just for the record it is all legal with all the LyCon tricks and processes. I just have to finish these FX3s so they can get to Sun & Fun and I can go hang an engine.
  27. #67
    Dec 2016
    Canyon, tx
    758
    When your GA Sensenich prop goes missing, I bet I know where to look. FedEx will probably be to blame for it also
  28. #68
    RaisedByWolves's Avatar
    Feb 2005
    4,382
    You should let him try your 84/37 so we can see the difference
  29. #69
    Dec 2016
    Canyon, tx
    758
    I’m interested also in the bottom end comparison. Tony should have that covered
  30. #70
    20,643
    We are planning a prop test session.
    Likes KevinJ, RaisedByWolves liked this post
  1. O-320 exhaust valve guide wear
    By irishfield in forum Super Cub Sick Bay
    Last Post: 10-28-2010, 04:14 PM
  2. 0-290d exhaust valve
    By whatsit in forum Super Cub Sick Bay
    Last Post: 10-26-2009, 05:19 PM
  3. PA-18 Fuel Valve Sticking
    By reileyr in forum Super Cub Sick Bay
    Last Post: 10-02-2004, 08:22 AM
