Originally Posted by
Cooley
Steve - thanks for posting this. A priceless video. I agree that I do have issue with operating reamer but after thinking about it more and watching your video i have to conclude that 70% of issue comes directly from CubCrafters.
if you closely look at the yellow fitting - you see that the hole was not really reamed thru, you can see a horizontal line inside the hole (the fitting made out of two plates) and untouched metal around it.
I have similar story on my left side fitting where I promise you - I did not screw up with the reamer and still have a play similar to what you have in your clips. When I reamed left hand side holes - the reamer barely touched the surface - it almost fell thru..
So my version is this:
they have 2 plates that constitute the fitting, 1/8 inch each. They drill 0.37 holes in each plate first and weld two plates together after. When they weld them together - they suppose to exactly line up these holes as 0.005 which is left for the reamer is not enough.
But they don't - the holes on two plates don't line up when they weld them together to the frame. So when you get your fuselage - you have upper plate misaligned with the lower plate, you ream it but since misalignment between upper and lower hole greater than 0.005 you get the slop we are talking about.
They (CC) either need to align the plated better or use 0.36 drill bit when making those holes. See pic below:
