Hi All
Can anybody tell me where I can find Piper part no 60764-03 Support Plate
I have searched Univair and Aircraft Spruce web catalogues to no avail.
see attached
PIP_SB0706B.pdf
Hi All
see attached
PIP_SB0706B.pdf
This one?
https://www.univair.com/piper/piper-...support-plate/
Excellent - that's the one!
Many thanks
Never heard of it or seen one. What's this all about?
"Always looking up"
The original tabs just welded on where separate and would break one pice is stronger and better. Most stuff up here was corrected along the way.
skukum12 thanked for this post
Its a plate to reinforce the lower tailbrace wire attachment tabs. Apparently due to corrosion these have been known to depart with variable consequences.
First mentioned in an FAA AD 81-06-08 dated Nov 19 1981
It is also mentioned with an included drawing in the Piper SERVICE BULLETIN NO. 706B dated Oct 1991 (PDF enclosed in my first post)
The Piper service bulletin mentions the serial numbers affected but it is probably a good idea to fit one even if you don't have one of the examples mentioned.
We operate two PA-18 180hp glider tugs, one has the mod and the other doesn't so I want to level up.
Towing gliders at full throttle all the time with the extra slipstream of the 180 puts a lot of stress on the tail structure in general.
CH
Got it. I have seen the single plate mod spanning the brace wire attach points. I just hadn't seen the more elaborate T shaped plate.
"Always looking up"
Yup. 2 separate tabs only welded to longerons. They might depart due to rust on or in longerons. New fuselages have one piece so not needed. I have a doubler or 2 laying around. I don’t put them on new fuselages without the flaw.
Deleted FaceBook, join me at https://www.mewe.com/i/mikeskup
Videos http://www.youtube.com/user/mcsrepair https://www.youtube.com/channel/UCIk...C-rmr3wpSuMT8g Pictures https://photos.google.com www.mcsrepair.com
www.SkupTech.comScooter7779h liked this post
As I recall the reason for this AD (we were told back then) was that cracks were being found in the fuselages after tig welding was introduced into the build process. Does anyone know when this happened?
The earlier cubs did not apply, so what would the difference be? I have an 18A (not applicable by serial number) in the shop now that the tabs attach at the longerons, but also wrap to the center around a 1/2 inch connecting tube. Looks plenty strong to me. Did piper change from this design?
Ed
A problem I’ve seen is dirt and moisture sitting on top of the junction between the tab and the longeron causing corrosion and pitting. The couple SuperCub frames I’ve redone, when replacing the lower longeron sections here, I make a strap that goes across similar to the Piper drawing, but haven’t had the tail that goes back to the tail spring bolt.
mike mcs repair liked this post
I've got a new one, never used, Univar with part number on it. Its been in my spare parts stock for years, don't think I will ever need it, have a new fuselage. PM me if someone wants to buy it. $30 and I will mail it USPS to US address.
PA-12 fanbarrow pilot thanked for this post
The original Piper ones are drilled to each specific airframe and one off one plane will not fit another. I have several from Super Cubs I have rebuilt. Li,e to see an AMOC for the AC on fuselage where you replace those finger brackets with a solid one.
Steve, they were airplanes outside the serial effectivity of the AD, so no AMOC needed. I think I just referenced AC43.13-1 Chapter 4 as my approved data. It was about 30 years ago.
RookieCubPilot liked this post
if still have one how much?
Ed
www.SkupTech.com
I assume that you're either a first responder, or in a high-risk category.
I'm looking forward to getting a vaccination, but I don't quite fit into any of the special categories.
Plus live out in a rural county (don't know if that'll be a plus or minus re getting a shot)
So I have no idea when I'll finally be able to get one.
if still needed i should have one i will look today
pipersc@hotmail.com
