Results 1 to 22 of 22
Thread: PIPER AIRCRAFT CORPORATION SERVICE BULLETIN NO. 706B 60764-03 Support Plate
    chadden's Avatar
    Jul 2020
    Ireland
    10
    Question PIPER AIRCRAFT CORPORATION SERVICE BULLETIN NO. 706B 60764-03 Support Plate
    Hi All
    Can anybody tell me where I can find Piper part no 60764-03 Support Plate
    I have searched Univair and Aircraft Spruce web catalogues to no avail.
    see attached Click image for larger version.
    PIP_SB0706B.pdf
    4,271
    This one?
    https://www.univair.com/piper/piper-...support-plate/
    chadden's Avatar
    Jul 2020
    Ireland
    10
    Excellent - that's the one!
    Many thanks
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    348
    if needed i have 1
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,175
    Never heard of it or seen one. What's this all about?
    "Always looking up"
    2,226
    The original tabs just welded on where separate and would break one pice is stronger and better. Most stuff up here was corrected along the way.
    Thanks skukum12 thanked for this post
    chadden's Avatar
    Jul 2020
    Ireland
    10
    Its a plate to reinforce the lower tailbrace wire attachment tabs. Apparently due to corrosion these have been known to depart with variable consequences.
    First mentioned in an FAA AD 81-06-08 dated Nov 19 1981
    It is also mentioned with an included drawing in the Piper SERVICE BULLETIN NO. 706B dated Oct 1991 (PDF enclosed in my first post)
    The Piper service bulletin mentions the serial numbers affected but it is probably a good idea to fit one even if you don't have one of the examples mentioned.
    We operate two PA-18 180hp glider tugs, one has the mod and the other doesn't so I want to level up.
    Towing gliders at full throttle all the time with the extra slipstream of the 180 puts a lot of stress on the tail structure in general.
    CH
    Thanks skukum12, barrow pilot thanked for this post
    chadden's Avatar
    Jul 2020
    Ireland
    10
    Quote Originally Posted by skysigns View Post
    if needed i have 1
    That's very good of you to offer. Would you have an FAA approval form for it or better still and EASA Form 1?
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,175
    Got it. I have seen the single plate mod spanning the brace wire attach points. I just hadn't seen the more elaborate T shaped plate.
    "Always looking up"
    11,721
    Yup. 2 separate tabs only welded to longerons. They might depart due to rust on or in longerons. New fuselages have one piece so not needed. I have a doubler or 2 laying around. I donít put them on new fuselages without the flaw.
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    796
    As I recall the reason for this AD (we were told back then) was that cracks were being found in the fuselages after tig welding was introduced into the build process. Does anyone know when this happened?
    The earlier cubs did not apply, so what would the difference be? I have an 18A (not applicable by serial number) in the shop now that the tabs attach at the longerons, but also wrap to the center around a 1/2 inch connecting tube. Looks plenty strong to me. Did piper change from this design?
    Ed
    798
    A problem Iíve seen is dirt and moisture sitting on top of the junction between the tab and the longeron causing corrosion and pitting. The couple SuperCub frames Iíve redone, when replacing the lower longeron sections here, I make a strap that goes across similar to the Piper drawing, but havenít had the tail that goes back to the tail spring bolt.
    Scooter7779h's Avatar
    May 2004
    Anchorage, Alaska
    1,032
    I've got a new one, never used, Univar with part number on it. Its been in my spare parts stock for years, don't think I will ever need it, have a new fuselage. PM me if someone wants to buy it. $30 and I will mail it USPS to US address.
    PA-12 fan
    20,352
    The original Piper ones are drilled to each specific airframe and one off one plane will not fit another. I have several from Super Cubs I have rebuilt. Li,e to see an AMOC for the AC on fuselage where you replace those finger brackets with a solid one.
    798
    Steve, they were airplanes outside the serial effectivity of the AD, so no AMOC needed. I think I just referenced AC43.13-1 Chapter 4 as my approved data. It was about 30 years ago.
    Likes RookieCubPilot liked this post
    Nov 2004
    Chattanoga, TN "outside"
    2
    u60764-002
    if still have one how much?
    Ed
    May 2004
    Anchorage, Alaska
    1,032
    Quote Originally Posted by sneek View Post
    Ed
    I still have one, undrilled, Univair part number stamped on it.
    You can PM me. However I would not be able to ship until the 22nd as Iím out at my cabin until my COVID-19 vaccine shot on the 22nd.
    PA-12 fan
    11,721
    enjoy cabin quarantining!!
    Nov 2004
    2
    Can't figure out how to find your private email address. Anyway I'll take part after your second shot if someone else has not got it. I can paypal money.
    Ed (Sneek)
    3,330
    ..... I’m out at my cabin until my COVID-19 vaccine shot on the 22nd.
    I assume that you're either a first responder, or in a high-risk category.
    I'm looking forward to getting a vaccination, but I don't quite fit into any of the special categories.
    Plus live out in a rural county (don't know if that'll be a plus or minus re getting a shot)
    So I have no idea when I'll finally be able to get one.
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    348
    if still needed i should have one i will look today
    pipersc@hotmail.com
    May 2004
    Anchorage, Alaska
    1,032
    Seniors over 65 are second group in Alaska and vaccinations started on the 10th.
    PA-12 fan
  1. Piper Service Bulletin 1044
    By Mutt in forum Super Cub Sick Bay
    Last Post: 02-20-2011, 04:52 PM
  2. Need copy of Piper Wing Rib Splice Service Bulletin
    By Mark Lund in forum Experimental Cubs
    Last Post: 09-25-2010, 06:50 AM
Tags for this Thread
