Also, I was using 1/16“ 70S-2 filler rod, a 1/16“ 2% ceriated tungsten, #12 pyrex cup with gas lens, stick out of about 3/4 gas cup diameter, and an on/off trigger on the torch. Although I can use my foot pedal on pieces like this the intent is to practice with the same setup I‘ll be using on the fuselage. I‘m also not using pulsing. I played around with it and thought it did offer value but the constant „flashing“ kept my eyes from being able to focus. I‘m talking the pulse flashing not flashing caused by contamination.
Someone brought up fit. I don‘t have any before pics but using my tube notcher I was able to get a reasonably tight fit up. A gap wasn‘t really present.
If it passes a destructive hammer test I am sure it’s going to do the job it needs to. Welding is like painting in the sense that it takes time to develop the skills to really be consistently proficient. The picture from Crash Jr shows what a skilled welder with good equipment will produce. If you don’t do this routinely you just can’t expect those kind of results. Keep welding, learn with every pass and have fun.
