Page 1 of 2 12 LastLast
Results 1 to 40 of 59
Thread: Aft fuselage metal belly
    Jan 2017
    PNW
    89
    Iím putting a metal belly on the aft 3í of my cub build. Iíve tried to find photos of how itís formed on the sides where it contacts the tubing but have been unsuccessful. If I roll the edges so it wraps part way around the outside of the tubing, water running down the sides will run into the belly. If I butt it up to the tubing, how could I seal it from water or exhaust fumes?
    If anyone has photos or drawings of what youíve done and ideas on how you would improve upon what you have it would be appreciated.
    Mr. Ed
    11,535
    you roll it up the sides some... you MUST also have front edge capture, if going to be used on snow, or it might bend down and shovel rear fuselage FULL of snow.....
    atlee sells a nice kit.. wow the price has shot up!$$$ http://www.fadodge.com/belly-pan-clean-out-kit/
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    265
    I was going to try and get a photo but my stupid iphone only takes these HEIC photos now that won't upload.
    Basically bring the sheet metal to the vertical centerline of the longeron and then roll the edge up slightly to keep the edge sucked up to the longeron. Don't wrap all the way outside, just bring the sheet to the middle of the tube or maybe just a hair past on the sides.
    Also, if you don't want to work too hard I know a place to get a prefabbed kit for a lot less than the Atlee kit and the sheet metal is way better built.
    20,193
    I use a radius die in my press brake to form the edges to roll up the longerons. The center has a brake so anything will run to the middle and aft and I wrap my longerons completely when covering. Here is a picture and a photo album link to several. https://photos.app.goo.gl/22EGjpZB6fsPxYnL7
    Jan 2017
    PNW
    89
    Thanks Mike. Since my fuselage is 4” wider and I carried the full width back another 3’, the taper of my empennage differs from the “normal”. Atlee kit probably wouldn’t fit so it’s “fun with the magnetic break” or build a roller for the edges. Do you happen to know the purpose of all the holes in the front end of the Atlee belly pan? Too many to be drain holes. Vent holes? Why would that be required?
    Jan 2017
    PNW
    89
    Thanks Steve, I can see now that those are rivet holes.
    Mr. Ed
    Jan 2017
    PNW
    89
    Steve,
    2024-T3 aluminum.......how thick are you using?
    thanks.
    20,193
    Pretty sure it was .020"
    Wolf Lake, AK
    5,650
    Pictures. Any water that enters from the pan or above will drain out in 3-point.
ID:	51914   Click image for larger version.
    Upper Peninsula of Michigan
    491
    I had considered doing this...but I couldn’t see the benefit in my case....it does give easy access to that section....what else do you guys consider a benefit? Is it for ruggedness in the Bush?
    20,193
    Most of the corrosion I find is the bottom longerons in this area. It gives you access to clean the grit and grime that accumulates in this area and it gives you good access to the trim system and tail spring attachment.
    Likes skywagon8a, NunavutPA-12, Crash, Jr. liked this post
    3,531
    Quote Originally Posted by Dan Gervae View Post
    Wouldn't access for cleaning/maintenance be a benefit? Even if you're not the one doing the cleaning/maintaining, 'easier' equals smaller bill from your A&P.
    55-PA18A's Avatar
    Dillingham, Alaska
    648
    Makes it easier to find and remove the the pens/pencils, lens covers, batteries, shotgun shells, etc that find their way under the floorboards and bounce back towards the tail of the airplane!! Being able to stick your head in there and take a good close look at everything is also kind of nice.
    Jim
    Wolf Lake, AK
    5,650
    For me it's the access to the electric trim actuator.
    Dave Barras's Avatar
    Jan 2004
    New Iberia, LA
    164
    For me its access to the pitch servo plus what Steve said.
    Dave
    YOU NEVER KNOW
    Meanwhile,...
    5,319
    Besides excellent access it's a great place to mount the transponder antenna and get that blooming noise generator away from the coms
    3,531
    That was you?
    Jan 2017
    PNW
    89
    Thanks to all you folks that responded. Fabricated and installed my version of the metal belly. I did the leading edge a bit different than Atlee or other folks photos. I formed something similar to the D window channel, only deeper. Both edges are rolled and it’s 1” deep. The vertical piece that attaches to the horizontal belly tube was then tig brazed to the U channel. I welded in tabs with nut plates (the long screws are temporary).
ID:	51952Click image for larger version.
ID:	51953Click image for larger version.
    Likes stewartb, Hardtailjohn, Olibuilt liked this post
    nd
    3,670
    would it work to make a little thicker and a lot larger aluminum rectangle grommet like these or even triangle shaped, could even make a 8 shaped grommet with a center web for added strength.dosent have to be as large as the belly pan is, leaving the bottom stringer in, and just large enough to get both hands up in there to work on stuff. then make a cover to fit like a inspection cover and fasten with screws and clip nuts or screw right into the grommet. if your not in brush i think these pans are a little overkill. was thinking in my allready covered airplane that i might do that. could run a couple L brackets off each side of the bottom stringer with nut plates also for a little more support for the cover.wish i never would have put those round inspection covers on the side under the stab.
    491
    Got it!!!...actually that all makes sense, I started down that path and must have gotten lazy...my fuselage was primed and I really didn’t want to tig the tabs on....I put the elevator trim in too so I used that as an excuse to be lazy. Yours looks really nice Mr. Ed! Now I have regrets. Oh well, maybe on the next one.
    11,535
    Quote Originally Posted by Mr. Ed View Post
    Thanks to all you folks that responded. Fabricated and installed my version of the metal belly. I did the leading edge a bit different than Atlee or other folks photos. I formed something similar to the D window channel, only deeper. Both edges are rolled and itís 1Ē deep. The vertical piece that attaches to the horizontal belly tube was then tig brazed to the U channel. I welded in tabs with nut plates (the long screws are temporary).
    what's your plan for the center belly stringer? i don't see it in that front piece..??
    Jan 2017
    PNW
    89
    Mike,
    I hope to have the stringer in place in the next few days. My elevator cables will run under the fuselage tubing. I want to get the fairleads in place first.
    10,683
    ...and just large enough to get both hands up in there to work on stuff. then make a cover to fit like a inspection cover and fasten with screws and clip nuts or screw right into the grommet.
    Are you a mechanic? How will you see what those hands are doing?
    Likes wireweinie, RaisedByWolves liked this post
    nd
    3,670
    nope and the same way as i do it through a couple of 3 inch inspection holes
    20,193
    steve, would it work to make a little thicker and a lot larger aluminum rectangle grommet like these or even triangle shaped, could even make a 8 shaped grommet with a center web for added strength.dosent have to be as large as the belly pan is, leaving the bottom stringer in, and just large enough to get both hands up in there to work on stuff. then make a cover to fit like a inspection cover and fasten with screws and clip nuts or screw right into the grommet. if your not in brush i think these pans are a little overkill. was thinking in my allready covered airplane that i might do that. could run a couple L brackets off each side of the bottom stringer with nut plates also for a little more support for the cover.wish i never would have put those round inspection covers on the side under the stab.
    I guess I need a drawing or something but get the just of what you are saying. I have threatened to install a pan on my covered airplane but just haven't figured it was worth the effort just yet.
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    265
    Having one of those square inspection holes onthe tail of my cub I would never do that over having a full tail pan to remove. Trying to fiddle with trim cables and stuff without being able to see much and with limited ability to move your hands up in there is the worst. I can't imagine you save much weight putting a couple inspection plates in versus just putting a tail pan on.
    Cub junkie's Avatar
    My Moms basement
    2,124
    Whenever I'm considering the weight of inspection panels for easier maintenance as being excessive I push back from the table and skip pie.
    11,535
    Mike,
    One trick I do if running cables down by fabric is make the cable go ABOVE the center pully, an below the other ones. Keeps cable from slapping the fabric and cutting a hole
    nd
    3,670
    not trying to save weight, and i will not cut up a covered airplane to put a belly pan in, and will not put the 2 round inspection covers on the side like piper did again either under the stabilizer. PO
    Likes pfm liked this post
    nd
    3,670
    going to have to lay underneath with a tape measure some day and do so measuring, these grommets you offer how thick are they?
    nd
    3,670
    Quote Originally Posted by Cub junkie View Post
    your not getting it.
    3,531
    Is that a clearance thing or a way to get a little tension between the pulleys?
    nd
    3,670
    see the 2 round ones, my OPINION is dont do it, a bitch to work through. or put them in but dont cut them out, would way rather work through the bottom.
    Likes Crash, Jr., mike mcs repair liked this post
    AkPA/18's Avatar
    Big Lake Ak
    728
    I moved my elevator turnbuckles to under the rear seat from the tail location. Always hated working in the tail to adjust stick position. And safety wire back there.
    http://thrustline.com/
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    265
    Totally agreed, the round inspection panels on the side are unsightly and of marginal utility. Didn't catch the part where where you were talking about modifying a covered fuselage.
    I think that you could probably install a full tail cleanout pan on a covered fuselage but it would certainly be difficult. Gluing grommets in is for sure a simpler arrangment.
    nd
    3,670
    Make one grommet but just thinking 9x15 with a web in the center. havent measured it.
    11,535
    a nice clamp in kit would probably sell well.....
    2,181
    WOW!!!! Did we just enter an alternate universe or did you just post you would choose to add weight to a plane for maintenance reasons? I will send you some info on 4 cylinder EGT/CHT insterments. Welcome to the dark side and feel the power of a well cared for aircraft!!
    20,193
    .025" 2024-T3 aluminum.
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    265
    And I'll send you my 4 band CHT that I tore out and you can keep it! I think you get me all wrong, I absolutely will add weight where needed (throwing a belly pod on this weekend). Those EGT/CHT/WTF monitors on the other hand...
    Not sure how you would accomplish a bolt in cleanout cover kit. Definitely something to look into though.
    Likes DENNY liked this post
  1. Metal Belly
    By kiwicubber in forum Super Cub Sick Bay
    Last Post: 03-28-2018, 06:35 AM
  2. Metal belly
    By streetreamer in forum Cafe Supercub
    Last Post: 08-02-2011, 08:52 AM
  3. metal belly vs. fabric
    By teeweed in forum Tales of the PA18
    Last Post: 10-19-2006, 08:27 AM
  4. Metal Belly
    By Aviator in forum Modifications
    Last Post: 08-07-2003, 03:27 PM
