Results 1 to 8 of 8
Thread: Lift Strut Angle ???
    Oct 2020
    4
    New members first post,
    Hi guys, just after some general information. Currently building a scale 85% Taylorcraft here in the UK. looking at the drawings, the lift strut angle looks a bit shallow at 20 degrees.
    What is the angle of a Super Cubs lift strut ??? ( A Super Cub should be my next project). thanks in advance.
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,358
    If I understand what you are asking for......... I just put a smart level under my forward life strut (on a Supercub) and it showed 22.1 degrees.
    Hope this helps
    Very Blessed.
    Oct 2020
    4
    Quote Originally Posted by Bill Rusk View Post
    Hope this helps
    Hi Bill, that's exactly what I was looking for, double checked current plans and 20+ degrees seems OK,( just.)
    Have clipped current wing build by 1 bay so hope to get closer to 25 degrees + - though.
    2,523
    What's the planned wing dihedral for your scaled Taylorcraft? Three quarter (Cub) to one degree (Taylorcraft ) is common. Dihedral can affect strut length.
    Oct 2020
    4
    Hi Gary, looking a 1 degree dihedral, strut tube is currently uncut, so will jig wing then cut to suit inc 1-2 degree washout.
    2,523
    That dihedral is good and the washout should be a good starting point. Later play with airspeed and stall behavior. Wash can also be used to accommodate available elevator trim range. Not enough nose down trim in cruise? Add more washout to dump some wing lift. Not enough nose up trim? Reduce washout to add more lift. Are you adding the typical Taylorcraft trim tab on the elevator? Make it duplicate the later models for area as the early pre-war like mine have a smaller size trim tab.
    Hardtailjohn's Avatar
    Marion, MT
    809
    I always wanted to build one with a jackscrew like a Cub. I bet that would be a sweet addition!!
    John
    Likes BC12D-4-85, Harold Cannon liked this post
    Oct 2020
    4
    Here in the UK were modding the LMA Taylorcraft (from Florida) to a new sub 300KG sector, will be using simple trim tabs in the first instance. The plan is to make a STOL wing, that will be retro fitted at a later date, then a new fuselage, so we end up with a full UK sourced product.
  1. Strut attach angle
    By Billy-250 in forum Tips and Tricks
    Last Post: 07-22-2010, 01:06 PM
  2. Lift strut and Jury strut bracing
    By pa19guy in forum Modifications
    Last Post: 11-17-2003, 12:22 AM
