There is a spec on the drawing but that is new tolernce. I let my conscience be my guide. The problems I see is that when there is a lot of play in the jack screw/yoke then it transfer out and you get play in the ears of the yoke to the front stabilizer carry-thru tube, the outside elevator bushings and the tail brace wires get loose and have to be adjusted. Bigger engines and longer props tend exasperbate the issues in my experience.
The Jackscrew comes out through the top. There should be a small metal cap with screws over the hole, I made a X cut over the hole and worked the cap out slowly. You may have to grind/file a bit if the hole does not line up, not a big deal just go slow. Once it was out and new Jackscrew in place I painted the metal cap and put it over the fabric. A dollar patch would work also. Just be prepared for the Jackscrew not to line up. Use zip ties to hold cable onto pulley as needed.
