Results 1 to 23 of 23
Thread: Baby Bushwheel
    Mar 2005
    Thompson Falls, Mt.
    170
    Baby Bushwheel
    I just bought a baby bushwheel tail wheel (used). What do I now have to do to get it on my certified super cub legally, exactly?
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,039
    Call Airframes Alaska and ask them for the paperwork and STC. They will also tell you to find a A&P/ IA to install it and fill out a 337 and send it to the FAA.
    May 2014
    727
    Better still, save yourself all that work, get your money back, and keep running the stock wheel.
    (on a cub I assume)
    less weight, less drag and you won’t loose a bunch of AOA.
    Cub tails are too light to benefit from B Bushwheel.
    my 2 c on the matter
    Likes PerryB liked this post
    TVATIVAK71's Avatar
    Jun 2016
    ANC
    81
    Quote Originally Posted by Oliver View Post
    (on a cub I assume)
    Yeah, the stock tailwheel makes an awesome brake when it buries itself on rollout on a soft beach or on Cook Inlet duck flats. But that’s OK cause the tail is light and you can lift it out of the trench it dug and set it off to the side. I personally like my Baby Bushwheel that’s my 5 cents on the matter.��
    20,175
    Does the seller not have the STC paperwork, usually doesn't have an N number written on it. If not call Bushwheel/Airframes and they can sell you te STC. Last I checked it was $50.All depends on your mission, removed my Baby Bushwheel while practicing for a STOL contest. Was a bitch to turn around on the gravel bars. Was glad when the STOL contest was over and I put it back on. For what I like doing with my Super Cub it is the cat's ass.
    Likes DENNY liked this post
    RaisedByWolves's Avatar
    Feb 2005
    4,209
    (on a cub I assume)
    Likes farm_boy252 liked this post
    Jul 2014
    Norman wells, NT
    47
    Did the main's make ruts at all?
    Feb 2005
    4,209
    Quote Originally Posted by farm_boy252 View Post
    Just a little bit you can see the mains on either side of the tailwheel. I wonder what a stock tire would have looked like
    Wolf Lake, AK
    5,642
    It would have provided enough drag to require more thrust to taxi but it would look essentially the same. Do it with a heavier plane and it gets worse. Ski season coming soon. Bring on the tail ski discussion!
    Likes DENNY, mike mcs repair liked this post
    Feb 2005
    4,209
    It would have provided enough drag to require more thrust to taxi but it would look essentially the sane. Do it with a heavier plane and it gets worse. Ski season coming soon. Bring on the tail ski discussion!
    One of these days I need to get a tailski. The cubs pretty light after the rebuild and the baby bushwheel has been working. We don't get snow like you guys though
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,168
    The baby is murder on the airplane in snow. Especially in wet sticky spring conditions. I will be going the 3200/tail ski route this year.
    Wolf Lake, AK
    5,642
    Burl's Magnum wide fork ski works great with the BBW.
    Thanks Brian M thanked for this post
    May 2014
    727
    To Skook’s point.
    Cub tailwheel mounting system is delicate at best. And all that extra mass banging around on the tail is hard on the airframe anytime of year.
    Sure, there’s exceptions using bby busheheel, Greg Miller landing on bowling ball size rocks comes to mind.
    Personally, I’ve never landed anywhere in a cub where I’ve regretted leaving bby bushwheel in the hangar.
    Once you get over the cool factor, and it does look cool!, Benefits of stock wheel on a cub outweigh bbbw.
    Again, my 2c.
    Doug
    Thanks barrow pilot, Eddy Lewis thanked for this post
    20,175
    I leave the tail till I can't with no issue. I like being able to taxi around on a gravel or sand bar with the BBW a lot easier than the standard 3200 and I believe it is easier on the tail because it is floating and steering on top instead of dragging sideways in the deep stuff.
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    1,039
    I stopped in to visit Will Rediske (RIP) and George N. And got my 185 tail wheel stuck in the Sand and needed the gang to get it out. Bought a new wide set up right after that. It really hits the old airspeed thou.
    Wolf Lake, AK
    5,642
    Big tires are all about reducing rolling resistance. If you aren't having a problem with a skinny tire you won't benefit from a wide one. If you need one? You know it. That's much more true with a Skywagon than a Cub. My 180 sees 600# on the tailwheel when loaded. Dragging that around will make you appreciate easier rolling resistance.
    Likes Oliver, mam90 liked this post
    May 2014
    727
    I used to fly a Maule, yes, baby bush wheel was very beneficial, cub not so much.
    Jul 2017
    14
    Worked on the Alaska Peninsula for many years doing guide support and Part 135, the Scott was all we had, back taxing with a load ate up a lot of props. The baby bush wheel sure helped!
    May 2014
    727
    Yep, there’s exceptions...
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,487
    Tailwheel ski test a few years back.
    https://youtu.be/BLnHL8evAWw
    Transmitted from my FlightPhone on fingers...
    May 2014
    727
    If they did he may have done one of these:
    Be careful out there.
    windy's Avatar
    Dec 2005
    Utah
    714
    Even a BBW can make a rut.
    10,673
    Be careful taxing that Twin Bee up on a beach. You just may need a lot of help getting it back in the water. I recall a certain beach on Sebago Lake. It will help if the beach was previously treated with bitumen.
    Thanks algonquin, RVBottomly thanked for this post
  1. Baby Bushwheel
    By Scouter in forum Cafe Supercub
    Last Post: 04-10-2015, 08:55 AM
