Results 1 to 11 of 11
Thread: PA-12 Carb Heat Box
    Oct 2020
    NJ
    2
    Question PA-12 Carb Heat Box
    Hi,
    Our airplane's ('46 PA-12) carb heat box developed some cracks. While we are getting it fixed, I'm trying to see if I can find a replacement.
    Can anyone suggest where we could get one?
    ...richie
    20,535
    Clyde Smith (Cub Doctor) makes one.
    11,343
    Randy Rubbert can make yours like new. And better, actually.
    Likes Mattpeed liked this post
    20,535
    The original PA12 air now is way different than anything else. They tend to crack out. $390 for new and improved.
    http://cubdoctor.com/miscellaneous-items/index.html
    Oct 2020
    NJ
    2
    Do you have contact info for Randy Rubbert?
    Thanks!
    20,535
    Quote Originally Posted by richieb View Post
    Thanks!
    (701) 847-3008 please report back what you find out.
    Kodiakmack's Avatar
    Sep 2020
    winters in Utah, Summers in Idaho
    113
    PA-12 Carb Heat Box
    Anybody had issues running a brackett assembly on the -12 box? We’ve had to do some fun mods to get everything to fit well.
    HAVE FUN. DON'T DIE.
    Jul 2012
    Montana
    468
    Do you have any pictures, I cant remember any issue with it. The bracket on my clyde smith airbox fits like it was born there, tho I did have to modify the airbox a bit to clear the accelerator pump.
    Mattpeed's Avatar
    Feb 2020
    Arlington, Ga
    13
    Randy and Logan are the best! I am running their airbox and lower cowl. Great folks.
    Matt
    20,535
    I installed the original PA12 box from Clyde and don't remember an issue with the Bracket Air Filter but did have the same issue as Doug with the accelerator pump.
    Kodiakmack's Avatar
    Sep 2020
    113
    Doug, hard to see maybe with my pictures but where we’ve riveted some silicone we also bent the flange out a bit. As it was, that flange on the air box was metal against metal and fretting the filter assembly. There was also an 1/8” gap on either side that the silicone now seals.
    The second photo shows the 1/4”+ gap at the aft end of the assembly. It could be the way the door is or some other defect, but the previous owner had just glued a piece of foam to the filter assembly to fill the gap (was almost coming off and threatening to be ingested)
    We plan on fixing some more silicone on the back end to take up the space and we should be good to go. Click image for larger version.
ID:	53174Click image for larger version.
  1. Robbing carb heat for cabin heat.
    By SkwentnaMan in forum Cafe Supercub
    Last Post: 02-18-2013, 09:21 AM
  2. Carb Heat or No Cab Heat
    By leobon in forum The Art and Science of Flying
    Last Post: 12-16-2006, 07:47 PM
Tags for this Thread
