Results 1 to 33 of 33
Thread: B & C 8 amp alternator with EarthX ETX104, Problem Help
    Mauleguy's Avatar
    Aug 2002
    715
    Long title I know. I have a problem that I can not figure out. I only have 8 hours on the airplane now and the first 5 were without any issues in regards to the alternator and battery. Here is what has happened in the last 3 hours.
    I was gone for a month and did not fly the airplane for around 8 weeks. This is a hand prop Lycoming 0-320, I am just using the battery to run GPS, com, transponder and a few EI gauges. The EarthX ETX104 is a light weight back up battery at 1.4 pounds that I was told would work for this application.
    The problem started in the 5th flight hour after I returned from Alaska and the aircraft had sat. I was flying along and it trip the 2 amp breaker, this is the one that is related to the overvoltage crowbar protection. I tried to reset it with in flight but is would not. I landed and looked everything over and start the aircraft again and the charging system seemed to be working again so I took off. In about the same amount of time it took to trip the 2 am breaker it did it again so I went back and landed and called it a day. I hooked the battery up to an approved charger (the one EarthX recommends) and charged it overnight. I went a flew it the next day and it seemed to be working fine and then I heard a pop in my helmet/headset and looked at the EI volt meter and it had a red overvoltage light blink and it showed 8.5 volts and I thought this is weird. I turned the master off flew back to the field and landed. Once on the ground I checked to see if it was charging and nothing. No breaker popped so I figured the voltage regulator failed after talking to B&C tech support. I ordered a new voltage regulator and looked all my wiring over and can not find any problem. I installed the new regulator and went flying today thinking I have fixed the problem. I would say at about the same amount of time into the flight the voltage regulator shut down (low voltage light came on) and I noticed it had stopped charging. I did not have a circuit breaker pop so I turned off my alternator field switch and flew around for another 1/2 hour then I turned the switch back on and it showed I was charging normal again. I decided to turn the switch back off until I figure it out so I don't blow up another regulator. I did turn down the voltage regulator from 14.4 to 13.8 based on a discussion I had with B&C tech support when I installed the second voltage regulator.
    Here is what I am thinking to try next, take the EarthX battery out and try a PC-680 battery instead.
    Is anyone else running this set-up (little EarthX battery) with the over voltage protection that B&C sells with the 8mp alternator kit.
    Thanks, Greg
    3,407
    So, double checking this. You had the B&C low voltage light on, but the 2 amp breaker did NOT pop, correct?
    Mauleguy's Avatar
    Aug 2002
    715
    The first 2 times the 2 amp breaker did pop and the low voltage light came on. Today after replacing the voltage regulator the 2 amp breaker did not pop but the low voltage light came on.
    Likes windy liked this post
    2,437
    There's some of these EarthX deals around here so I thought I'd read up some: https://earthxbatteries.com/shop/etx104
    I have a B&C 200G 12A so hope it gets figured out and works.
    May 2014
    693
    Sd8 alternator?
    i just put the same setup in a Pitts, (earthx, B&c with overvoltage) haven’t run it yet but will follow this closely.
    i know they recently revised their overvoltage/regulator unit, assuming that’s what you’re running?
    May 2014
    105
    I run the B & C 8 amp vacuum pad alternator with an EarthX (and handprop).
    The EarthX will soak up a huge amount of amps when charging, but at least in my application, it will simply lower the voltage as it runs out of available amps to charge. I have yet to trip the 2Amp breaker on the overvoltage protection crowbar circuit, but can manually trip it and break the charging circuit. Are you sure the crowbar circuit is wired correctly? It took me a bit to fully understand what was going on when I initially installed it as the wiring was a bit goofy.
    Somewhat related, I noticed the regulator gets warm-to-hot when at its upper range of amperage. I fab'd up a heat sink which helped in that area:
Name:	6yAUQe6V3aKDxr7qBC1akxVPkm_2sNeGzqYzH9OxtCgBLo8n1xrhQe4ADQ7zyMQRkq7Uht34DismbFnKBXdxFFoAGTGRy2Mc.jpg
    Edit: FWIW, I run an entire D180 glass dash, Trig radio and ADSB transponder, and charge my tablet (MFD) without any issues on this little B&C alternator without having to fallback to the EarthX. I set the charge rate at 14.3ish volts with no problems.
    May 2014
    105
    If this helps, here was the diagram for my install:
    Mauleguy's Avatar
    Aug 2002
    715
    Yes I followed that diagram and yes the set-up that motosix has is the one I have. Attached the regulator to .050 aluminum for heat sink, I felt the regulator as soon as it stopped charging today and it was barely warm.
    Curious if you run this small battery or the larger earthX. I run the larger
    May 2014
    105
    I run the ETX680:
    https://earthxbatteries.com/shop/etx680
    I initially used it with a starter but I have since removed the starter and associated mess, so I would prefer to run the 104 at this point.
    May 2014
    105
    Note in the diagram that the 2Amp breaker trips at 16volts. I am curious how you are getting to that voltage?
    You have the diode installed correctly in the crowbar circuit, yes?
    3,407
    Quote Originally Posted by Mauleguy View Post
    The only way you can have a low voltage light (the alternator low voltage light, not the E.I. low voltage light) and the 2 amp breaker does not pop, is if the relay does not energize. This could be from a relay failure or from bad connections at the coil connections on the relay. To be honest, I don't use the relay sent with the SD-8 kit. I use a 'fog light' style relay as it's sealed and there are connector blocks available for them instead of just female spade terminals.
    Mauleguy's Avatar
    Aug 2002
    715
    Well according to the tech guy at B & C if the EarthX battery is low it is like a sponge and will allow more than the 14.4 volts through. That is where the crowbar comes in and trips at 16, I never saw 16 volts on the voltmeter as I was flying or the overvoltage light I my EI gage so not sure about it other then it did trip the 2 amp breaker which the tech guy told me it was doing it's job. The tech guy also said I may have a problem with the relay so after wireweinie's last response I will switch it out since I also bought another one of them. The tech guy said if you have a problem with the diode it will split if you have it back ass wards which I know I don't (verified that already) he also said the capacitor is pretty bullet proof (will start to leak or buldge).
    I think I am going to put a new relay in place and run the PC680 battery and see if the problems go away. If they do then I may look at why the EarthX is not working for me.
    I run the ETX900 in Bushwacker with the 20 amp B&C accessory mount alternator and no problems, but it is a different animal so not apples to apples comparison.
    Thanks for all the help.
    2,437
    Is the battery worth the weight savings and maybe grief? My B&C and Odyssey SBS J-16 whatever seem to work. 10# diff? I could never tell the diff. My winter gear weighs twice that.
    3,407
    The voltage regulator will control voltage in spite of the current flow, that's it's job. EarthX batteries are sized according to the current output (amps) of the alternator. The battery needs to be large enough to handle the max output of the alternator in the system. This means you can pair a larger battery with a small alternator with no problems but not the other way around.
    If the crowbar trips the 2 amp breaker in this SD-8 system, that means there has been, or it thinks there has been, 16 volts or more at the alternator output.
    Yes. The diode will split in half if you connect it backwards. Every time. Sigh
    If you are going to replace the the relay, consider going with a sealed style. If you stay with the ones from B&C, install new terminals on the wires during replacement.
    Likes barrow pilot liked this post
    Mauleguy's Avatar
    Aug 2002
    715
    Post #13, I kind of think it is not at this point
    Web, It looks to me that it should work (max charge rate 10 amp) but at this point not sure. I have never seen the voltage of the battery below 13 volts when the system has shut down and I am simply running on battery power so not really sure what is going on. I read somewhere on EarthX site that the battery minimum voltage is 13.28 and maximum is 13.9. I have never seen this battery at 13.3 or higher so maybe I have a dud. When I charge it overnight with there recommended charger it only shows 13.1 when I flip master switch on, maybe my EI gage is off though.
    I will go with your recommendations on terminal ends.
    Which relay would you use if not the B&C, do you have a link.
    11,370
    My guess is you lost a cell in the battery. Or intermittently loosing it.
    5,475
    Two of my very favorite providers for tech support for my planes have been B&C and Reg @ EarthX. Both have been very accessible and very helpful.
    Is the battery flashing a code?
    Mauleguy's Avatar
    Aug 2002
    715
    Web, I have a friend who uses this alternator and this same battery, he eliminated the relay and crowbar and went direct with the red and black wire off the voltage regulator. He says the battery has all the fail safes built into the battery and that he can see if there is a problem with his gauge and shut system down if there is a problem. The battery has a indicator light so that is an additional warning light (I did not hook that light up but I could).
    What do you think about running the system without the crowbar and relay, he told the owner of B&C what he was going to do and the guy just shrugged.
    I like simple and if the battery has all these built in protections why even use the crowbar...
    Mauleguy's Avatar
    Aug 2002
    715
    Is the battery flashing a code? Have not paid attention, I could look down and see it but actually had not thought of looking at the battery light as stupid as that sounds.
    My ETX900 has an indicator fault light on it, I am actually not sure if this battery does so the answer is probably no because I did not hook up the pig tail off of this battery.
    Just went and looked at the battery picture and it has the same built in indicator light but the answer is still no.
    5,475
    I have two EarthX batteries in the hangar. Not charged to several months. 13.3 volts.
    Look at page 7. I had a brand new battery with a failing cell according to the LED code. EarthX sent me a new one via Fedex. https://earthxbatteries.com/wp-conte...00-TSO-ICA.pdf
    Mauleguy's Avatar
    Aug 2002
    715
    Thanks Stewartb, sounds like maybe the battery is the problem. I will take my good voltage meter with me today and see what it checks on the bench when I pull it out. It has been charging all night so it is not going to get any more charged then it has been.Click image for larger version.
    This is the charger I have been using and it is one that is recommended on EarthX web site. I do notice is says on the front of the charger 12.8V so not sure if that means that is the maximum it will charge the battery to...
    5,475
    I have the same charger. FWIW, when I had the battery failure the Optimate diagnostics didn't detect it.
    3,407
    BEFORE you replace anything, troubleshoot.
    You'll need to monitor the voltage closely to see what it does when the system goes off line. Does the voltage actually go above 16 volts? Does the system simply stop charging? And use a quality hand held meter to monitor bus voltage as they react much more quickly than panel mounted instruments.
    I'm not sure about removing the crowbar from the control circuit. It's not only there to protect your battery, it's also there to protect your instruments and avionics. Can you really be sure that you won't miss a high voltage incident in time to protect you equipment?
    If you leave a battery on a maintenance charger the recommended voltage is 13.3 to 13.9 volts. The charge voltage when on the aircraft is recommended to be 13.9 to 14.6 volts.
    Troubleshoot first!!!
    Last edited by wireweinie; 10-17-2020 at 11:42 AM. Reason: My English teachers are SO disappointed
    Likes cubflier, mike mcs repair liked this post
    cubflier's Avatar
    Nov 2003
    1,301
    An EarthX battery will have a tendency to expose flaws in your charging system where as the more tolerant PC-680 will cover these flaws up. Like said above nail down your voltages first before you start switching things out.
    With regards to any initial EarthX battery, a reasonable practice is to partially discharge the battery down to say 13V. Then stick it on the Optimate overnight and check the top off charge of your battery the next morning. Then install in aircraft.
    Good Luck - Jerry
    If it looks rough...it is!!
    2,437
    If the battery says it's had enough charge there must be a transition from a previous state at the alternator or regulator. Does the alternator dump current through the regulator if not needed....the heat sink...to the firewall? Could there be a brief voltage peak if the battery declines a charge and before the regulator catches it? Harley Davidson dumps unneeded power through the regulator for example but maybe not the same apple.
    Mauleguy's Avatar
    Aug 2002
    715
    Product specifications from there web site. It is interesting that the recommended charging amps is .8-5A
    In flight at 2600 rpm I see more then that continuous so maybe that is the problem. I am running higher RPM then I normally would be while breaking engine in.
    Voltage 13.2V
    Capacity 4Ah @ 1C Rate
    (See chart)
    Capacity vs Temperature 25 C = 100%
    0C = 92%
    -30C = 80%
    Self-Discharge Rate < 3% / month @ 25
    C
    Absolute Max Discharge
    Amps
    10A (built-in auto
    resetting fuse)
    Continuous Discharge
    Amps <20 C
    8A (built-in auto resetting fuse)
    Amps >20 C
    6A (built-in auto resetting fuse)
    Standard Charge Voltage 13.9 - 14.6 V
    Maximum Charge Voltage 15V
    *****Recommended Charge Amps .8 - 5A*****
    Max Charge Amps 10A (built-in current limiting)
    Life (Charge cycles, 80%
    depth of discharge)
    2000 cycles @ 1C
    discharge rate, 25C
    Life (Years) Up to 8 Years
    Weight 1.3 lb. (.6Kg)
    Dimensions 4.5 in (L) x 2.6 in (W)
    x 3.7 in (H)
    113mm(L) x 66mm
    (W) x 95mm (H)
    Environmental Rating
    (resistance to water intrusion)
    IP 66 (wash down
    with a high pressure
    washer)
    Operating Temperature -30 C to +60 C
    Storage Temperature -40 C to +70 C
    I was curious about my other airplane with an EarthX EXT900 and what the voltage would read at the battery. I have not flown the airplane since I got home from Alaska on Sept. 26th and with my voltage meter it reads 13.96 volts at the battery.
    I am using the B&C 20 amp alternator on that airplane so different I know.
    3,407
    Make sure your alternator voltage is between 13.9 and 14.6 volts. Then fly it and note the amp reading on the panel. If the ammeter is installed in the main bus wire, this reading is an exact measurement of the current being sent to the battery. If the ammeter is installed in the alternator output lead, this reading is a measurement of the current being sent to the battery PLUS the current sent to all the other electrical items on the aircraft, such as lights or radios. .8 to 5 amps recharge rate is ideal but damage will not occur until the amp flow exceeds 10 amps. And that should not happen with an 8 amp alternator.
    3,669
    Maybe a dumb question re the 8A alternator rating - is that the max the alternator is capable of producing? Or is that merely a thermal limit, beyond which the alternator would damage its self? Maybe that's not even pertinent to the situation, just tossing it onto the table - - -
    10,519
    Do you have a good volt/ammeter? I've found this Davtron M475VAA to be excellent. Accurate to tenths of a volt/amp. Reads alternator output amps, amperage flow to/from the battery and system volts.
    https://www.davtron.com/product-deta...?M475VA-VAA-11
    3,407
    It's a max output rating. If you try to overload the alternator, the voltage will drop off and limit the output.
    Thanks Gordon Misch, mike mcs repair thanked for this post
    2,437
    It might help to monitor the EarthX external LED light's behavior. See pages 3-4 for setup and diagnostics: https://earthxbatteries.com/wp-conte...l_111017_Y.pdf
    Mauleguy's Avatar
    Aug 2002
    715
    Update!
    I put a new B & C relay on today and added the led light for battery into instrument panel. I have an EI gage, don't plan on changing that.Name:  shopping.png
    I had the battery on the charger since yesterday and when I disconnected it, I then checked it with the EI gage it read 13.3 volts.
    I also checked the voltage with my handheld voltage meter and it read 14.26 so I am guessing that my handheld one must be off....
    I went and flew the airplane for almost 2 hours, the voltage meter read 14.2 volts and was showing .6 to .8 amps of charging at RPM (2500-2600). It was showing almost 6 amps of charge right after I took off but fairly quickly settled into .8 amps soon into the flight. I shut down one time and for the most part was doing take offs and landings most that time so my RPM's varied.
    I think I fixed it but probably to soon to celebrate, at this point my money is on a faulty relay that maybe also took out the voltage regulator. I will send them into B & C for warranty and see what they say.
    The EarthX Led never flickered once.
    Thanks for the advice.
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    853
    L
    Thanks, Greg
    I had a similar setup when I was hand propping my O-360 SuperCub. The small gear driven B&C 8amp alt and regulator thing, with a very small EarthX battery. Everything has been trouble free, summer or freezing winter.
  1. EarthX Battery 337 in a Certified Super Cub
    By Steve Pierce in forum Member to Member
    Last Post: 08-10-2020, 12:04 PM
  2. EarthX ETX36D Tear Down And Surprises
    By cubflier in forum All Things Electrical
    Last Post: 05-20-2019, 05:49 PM
  3. EarthX and B&C Charging System
    By stewartb in forum Experimental Cubs
    Last Post: 02-27-2019, 08:07 AM
  4. EarthX Jump Pack
    By King Brown in forum Products, Purchases, Reviews & Prices
    Last Post: 04-14-2017, 09:38 AM
  5. PA-12 Alternator STC/PA-18 alternator question
    By glassjet in forum Experimental Cubs
    Last Post: 12-27-2005, 01:39 PM
