Results 1 to 34 of 34
Thread: Another Plane power issue
    S2D's Avatar
    May 2002
    Montana
    4,253
    Wirewienie
    Since you had such good luck diagnosing Gordons problem hoping you could figure mine out.
    Cessna Agtruck running the plane power system.
    Ran fine for a couple years.
    Suddenly this summer it starts spiking and kicking out for a while then kicks back in
    repeating the process til it finally burnt the regulator out.
    Pulled the cowling and found severe fuel leak in that area. (yea thats a whole nother "Holy $hit" story !!!!!)
    Fixed the fuel leak and replaced the regulator.
    everything would work fine under 1000 rpm but above that, same story til finally burnt out another regulator.
    So now I finally get it in the shop for the winter annual and have to figure out whats causing that !!
    Wire shorting ?? loose ??? vibration induced ????
    thanks
    Brian
    3,709
    https://planepower.aero/wp-content/u...lternators.pdf This didn't do me much good, but maybe??
    I have a voltage regulator enroute from Spruce. If you want, and assuming I confirm I don't need it, I can send it to you instead of returning it to Spruce. I'd cover the UPS from me to you.
    S2D's Avatar
    May 2002
    Montana
    4,253
    Ok. That works for me.
    Sent from my E6910 using Tapatalk
    3,526
    What did the voltage do during these episodes? Was the voltage constant at 14.2 volts during normal operation? Was it 'kicking out' for high voltage or high current?
    3,526
    Ok, listen up. The next guy installing a Plane-Power alternator, contact me! I'm making your wire harness for your new charging system!
    Just trying to save time . . . .
    S2D's Avatar
    May 2002
    Montana
    4,253
    The ammeter was pegging. Doesnt have voltmeter.
    S2D's Avatar
    May 2002
    Montana
    4,253
    Yea im sure that would help.
    I replaced a lot of worn out wiring about 8 years ago.
    But these things take a lot of abuse and im sure a lot more is going to get replaced before i find the problem.
    3,526
    The pegged ammeter obviously shows huge current flow. Put a digital voltmeter on the bus and check it when the system acts up. In general, normal or lower voltage means a shorted wire or contact. Higher than normal voltage means possible voltage regulator issues.
    Is the ammeter installed in the alternator output lead or on the main bus feed? If on the main bus feed, does it peg to the positive side of the ammeter or to the negative side?
    P.S. I'll need the length of wires required if you have a non standard Cessna install.
    S2D's Avatar
    May 2002
    Montana
    4,253
    You mean you have the data to make a complete harness for a cessna Ag truck?, Or are you just talking about the alternator circuit?
    Ill check what you asked when i get back , I gave the mechanic enough other discrepancies to fix to keep him busy for a week or two.
    3,526
    I'll do the whole aircraft, including avionics/accessories if you give me the info I need.
    3,526
    Year/serial number of aircraft
    List of all avionics by make and model
    List of accessories (I'll need diagrams with the ag items. Don't have much access to that stuff)
    List of all items such as nav or landing lights that have been changed over to aftermarket stuff.
    Do you want factory markings on airframe wiring?
    All wires will mil-spec M22759/34-* or M27500-* wiring, white, with laser engraved markings
    Likes S2D liked this post
    S2D's Avatar
    May 2002
    Montana
    4,253
    Wow.
    The pilot that owns and flies it for me would love that. Hes always claimed its jinxed.
    Ill see what i can come up with.
    No avionics, just gps, flagger and crophawk.
    S2D's Avatar
    May 2002
    Montana
    4,253
    We wound up going thru the wiring, eliminating some possible problems, tightening some grounds etc.
    Will see how that works out before ensuing this route.
    7,278
    Wow, Web. That is a neat trick, building an entire harness. I did it once on an old Ford - I was really puzzled about this heavy wire that seemed to connect everything. That was in high school, before I learned about circulating grounds.
    My Decathlon could use such an improvement - the smart folks at Bellanca made an accessible switch panel, and forgot to leave enough wire for it to flip open. Drives me nuts when a switch fails (so far, two). If I ever have to recover, it gets a new harness. Yes, Plane Power. No, it has been trouble-free.
    Jan 2017
    Utah/Alaska
    184
    I have a customer that wants a new light weight alternator, I am thinking of just sticking a 89 Geo Metro one on...at least I can replace it for $65.00 which is way cheaper than the Plane power ones. I do know he would like a new wiring harness too, but that may happen at recover. Tim
    3,526
    Quote Originally Posted by astjp2 View Post
    One of my rants, so if you've heard it before, just bear with me.
    Automotive alternators with internal regs draw the regulator power from inside the alternator. Not a problem under normal conditions. The field current is controlled by a transistor inside the regulator. When semiconductors fail, 99% of the time its to a shorted state. In a regulator, this means that the shorted transistor controlling the field current will simply dump as much current into the field as is available. This produces high voltage. This, in turn, means more current will be available to the field, which increases the output voltage again. Etc, etc, etc.
    Just pull the output breaker? Ok. When that happens, you'll disconnect the alternator from the bus bar, but the alternator will not stop producing power. Remember that the reg gets it's power from inside the alternator which is still producing. So even with the alternator disconnected from the bus, it will continue in an over voltage state until the engine is shut down or it burns up. I've opened car hoods and seen the melted copper and solder slung around. I will NEVER take a chance on that happening in an aircraft.
    Thanks Speedo, barrow pilot thanked for this post
    S2D's Avatar
    May 2002
    Montana
    4,253
    Proper routing and securing seems to be the most important thing.
    After replacing a couple worn wires and securing properly, seems to function normally with Gordon's new regulator !!!
    Likes mike mcs repair, Gordon Misch liked this post
    774
    And if you EVER consider an EarthX battery, never install one with an alternator with an internal regulator!
    3,526
    What's the story there?
    Likes barrow pilot liked this post
    aeroaddict's Avatar
    Mar 2016
    Boise ID area
    115
    Why would that be? Considering EarthX batteries are for ATV's, UTV's, race cars, motorcycles, sleds (snowmobiles), ...... it would seem they are designed to work with automotive type alternators.
    supercrow's Avatar
    Dec 2008
    423
    I am still using an alternator that was used on the Honda Civic. Put it on the original build 24 yrs ago and have had no problems so still running it. It has an external regulator and I have been running the EarthX battery for the last year and a half. I did use a pulley that used to be available at Spruce to slow the alt. speed because of the large aircraft flywheel. It is small and light (30amp ) and works very well for me. Would replace with same if i needed one.
    Mar 2016
    1,553
    I have a bit different opinion about internal regulators. My background has been a mix of aircraft and road race and rally cars. These cars are about the harshest environment out there with the driveline solidly mounted to the chassis. The rally cars run very high current load with all the lighting for long periods. Most every car has been either 4 or 6 cylinder which have rather high vibration loads.
    In the mid 70s I saw one fresh rebuilt alternator fail high when new, this was the last external reg unit in a car I have touched. A bad alternator that did damage. Every other charging system failure went low causing no damage whatsoever, and that has not been many failures. Most currently one road race car had repeated wire failures right at the alternator during track sessions all resulting in DNFs, tiny batteries do not keep fuel injected engines alive very long.
    The common failure I have seen in aircraft has been a failed crimp terminal at the alternator causing system failure. Once I started replacing the field wire so I could get a good strain relief those failures became rare.
    My own airplane will use a Denso or Mitsubishi alternator as every race car has, no off brand look alike with components sourced from who knows where.
    Regards, Charlie
    3,526
    External automotive charging systems are what the stock systems are on small aircraft. The wiring between the reg and alternator allow for a manual control switch (one pole of the master switch) to be installed. This switch is what turns off the regulator power to de energize the field.
    3,526
    If I didn't do the installation, I can't help with bad wiring/poor connections, lol.
    But as far as regulator failures, I stand by my original assessment. Just looking at the regulators, they tend to fail in a shorted mode. This is separate from alternator failures such as worn brushes or bearings. If this happens, there needs to be a means of disconnecting power from the alternator field to prevent continuous over voltage and over charging. Worse case scenario for even competition cars is to end up stalled out. Aircraft systems use a switch and breaker combination to control the field for safety, do you have a similar arrangement in the rally cars?
    S2D's Avatar
    May 2002
    Montana
    4,253
    In all the years of flying these cessna spray planes, we've had one runaway alternator.
    Pilot said turning the master off didnt help.
    Fried the guages but didnt hurt the wiring.
    This system had an overvoltage sensor in it but that didnt stop it either.
    Jan 2017
    Utah/Alaska
    184
    For those of you who want to use an earth-X battery, read this service bulletin from Remos one it’s call out for a different regulator to keep from having problems with it. Tim
    https://remos.com/wp-content/uploads...ft-battery.pdf
    sjohnson's Avatar
    May 2002
    Boise, ID
    723
    Just curious, was the voltage regulator an earlier electromechanical type or a newer solid state type?
    Make friends, because life isn’t fair.
    3,526
    Sounds like it was mis wired. Shutting off the field switch should have de energized the reg system. And the fact that the OV relay didn't trip raises a HUGE red flag.
    S2D's Avatar
    May 2002
    Montana
    4,253
    Quote Originally Posted by sjohnson View Post
    Pretty sure it was the old mechanical
    S2D's Avatar
    May 2002
    Montana
    4,253
    That hold true even if the field wire shorted to ground
    3,526
    Stock Cessna systems use a reg that supplies power to the field windings which, in turn, go to ground inside the alternator. So if the field wire was shorted to ground, no power would get to the field windings and there would be no alternator output.
    supercrow's Avatar
    Dec 2008
    423
    I monitor both volts and amps and have a field switch right beside my master just in case. Have always felt pretty comfortable with it. The old Honda Alt is a Denso.
    3,526
    The typical setup is the field power supply routed from the field breaker, through one pole of a two pole master switch, then out to the reg. This allows you to de energize the field by manually popping the field breaker. It has the highest safety factor because you can isolate the battery and de energize the field with one switch throw. Electricity is always faster than that second switch.
    Likes mike mcs repair, BC12D-4-85 liked this post
    774
    Quote Originally Posted by aeroaddict View Post
    The EarthX TSO limits use to electrical systems with alternators having external regulators. Guess just one more method to isolate the charging source in the event of an over voltage.
  1. Plane-Power
    By wireweinie in forum All Things Electrical
    Last Post: 02-26-2017, 06:05 PM
  2. Plane power regulator
    By Krick in forum All Things Electrical
    Last Post: 10-24-2016, 05:44 PM
  3. August issue of Plane and Pilot
    By 180Marty in forum Cafe Supercub
    Last Post: 07-19-2007, 05:38 PM
