Results 1 to 16 of 16
Thread: Making aluminum interior panels (necessary tools?)
    Jan 2013
    Hudson, MA
    60
    I am thinking about trying to make new aluminum interior panels, but am wondering if it is possible to make them well without expensive tools and a sheet metal brake? If the results will be lousy I will probably outsource the job.
    Also, I was going to go with 3003 H14 .020 aluminum, but is 2024 T3 bare .020 or another product better?
    11,055
    Kydex.
    Likes Southern Aero, barrow pilot liked this post
    11,370
    Kydex is what I use.
    Used to always use 2024-t3 .020”
    Equipment varies. With kydex I just heat bend it over a pair of strait edges/square tube.
    May 2014
    693
    I second Kydex
    alot easier to work and way more durable, no paint process required,
    You’ll need a 36” brake, straight edge and razor knife. L side passenger throttle channel requires 48” bend but can be done in 2 pieces with 36” brake.
    MCS Mike has posted some great info on working with Kydex.
    found another photo, inexpensive light duty brake in the background:
    Thanks mvivion, stknrddr thanked for this post
    Sep 2011
    64
    Which "model number" of Kydex?
    5,475
    Nephew's doing Oratex for the interior. A good use for that stuff. Easy to glue, easy to shrink, no paint, no special tools, and there's nothing lighter except... nothing.
    If you choose to use Kydex add lots of tabs. It needs to be attached at closer spacing than aluminum or it'll rattle. Or watch Mike's videos for how to form ribs into the panels to stiffen them. A shear and break are still handy. Perhaps not required but you'd be happier with them than without.
    Kydex has lost market share to carbon fiber, whether doing your own or buying the pre-made panels from Carbon Concepts, carbon is lighter and stiffer. And itchier to work with!
    Jan 2013
    Hudson, MA
    60
    Thank you for the replies. Oliver, that Kydex looks great. Did you use it on the rear seat? In any case, I like that set up a lot-- I'd like to get rid of the old spring seat and go to a platform seat.
    If weight is a key factor, what is the best thickness of Kydex to go with?
    2,118
    I am telling my wife I need a 4 ft shear, 4 ft brake, roller, bead roller, and english wheel to do it right. That is my story and I am sticking to it.
    5,475
    Quote Originally Posted by DanP View Post
    Kydex weighs half as much as aluminum. I posted the weights in an old thread about 10 years ago. I used .040 Kydex on sides and bailed on using it for a headliner because it was too flexible. MCS Mike uses .060 primarily, if memory serves. Forget about .028. It's to flimsy to be useful.
    Apr 2015
    Platinum
    270
    .028”. Is great for covering small areas that don’t need rigidity in the panel..
    Sent from my iPad using Tapatalk Pro
    Jul 2006
    AK
    87
    I have made only one set of aluminum interior panels and floor boards. A set of tin snips, dremel, and large table/bench are a basic start. I really liked the sheer, it worked on my poster board templates and aluminum. The brake was also very handy for making 90's and creases. So I would say sheer and brake would speed up the process substantially and it's a long process anyway for a first timer. The longer the sheer and brake the better.
    11,370
    this is a nice machine, I have one, price is good, went up $200 since i bought mine decade or so ago...
    https://www.grizzly.com/products/Gri...-Machine/G0629
    the only problem with it is I cannot make it do long strait bends.... always have some bow in bend....
    5,475
    On my wish list! I like that machine.
    11,055
    Quote Originally Posted by Oliver View Post
    I second Kydex
    That is a GREAT looking interior!
    Thanks Oliver thanked for this post
    May 2014
    693
    Dan,
    rear seat and storage area floor are .050 aluminum.
    carbon concepts under seat storage tray and airframes Safari seat.
    safari seat mounting tabs are visible at the corners of the access lid for under seat storage,
    im really happy with this setup, lightweight and versatile, safari seat is a good solution to replace original seat, and still pretty comfortable (I’m told)
    Re kydex: I think .040, and yes more mounting tabs helps securing everything.
    bend 90° angles where panels meet floor and secure panels to floor helps with panel stiffness as well as keeping dirt and crap out of belly.
  1. Interior panels
    By C-YQK in forum Tips and Tricks
    Last Post: 09-04-2015, 06:55 AM
  2. Interior panels
    By Dbow in forum Cafe Supercub
    Last Post: 04-27-2014, 06:37 AM
  3. Softer aluminum on interior panels?
    By Aviator13 in forum Modifications
    Last Post: 07-30-2013, 06:02 AM
  4. Interior panels for SQ2
    By d_kandle in forum Experimental Cubs
    Last Post: 02-22-2010, 11:22 AM
