Results 1 to 19 of 19
Thread: Titanium angle stock availabilty
    Jul 2016
    Anchorage, AK
    131
    Hello, im looking for titanium angle stock 1.5x1.5x.250” to make long steps for my gear legs. I have a request with a local metal shop but cant seem to locate any. Does anyone have any ideas in case my metal shop is unsuccessful.
    Thank you
    10,519
    Look for some flat stock and bend it in a press brake.
    3,407
    I've never worked with Ti flat stock. How does it handle in a bend?
    10,519
    I have never worked with titanium at all. I'm certain it must be bendable. 1/4" would be quite stiff. Press brakes do a nice job of bending. Doesn't someone make gear legs of titanium for Cessna 180/185s? They would be thicker and have been bent.
    Mar 2016
    1,515
    I would not even try to bend .250 in a press brake. Maybe .095 or up to .125 I can not even comprehend the need for .250 unless an Elephant is climbing the step. But then the gear leg would fail.
    Regards, Charlie
    10,262
    What's wrong with aluminum angle?
    Nov 2015
    Fairbanks, AK
    41
    What he said. For a step, aluminum is fine. Unless you just want the “cool” factor of Ti, aluminum is lighter. If you really need tough, skip the 6061T6 you’d get at the local welding shop and order up a stick of 2024T3 or T4 or for top toughness and strength, 7075T6. Spruce carries the 2024, 7075 you’ll have to search a little further for.
    If you want really sexy, try some float step material that Aeroset sells. It’s a tad pricey though.
    Mike
    Nov 2015
    Fairbanks, AK
    41
    With the heat treated alloys (2024, 7075)you can probably use 1/8” angle and get the same results for a step at almost half the weight. No downside to shaving weight!
    Mike
    11,370
    I've had to straiten steps in my press, the 1/4" thick, no lightening holes drilled atlee steps.... they WILL and DO bend...
    Jul 2016
    Anchorage, AK
    131
    I drew a blank on metal weights. Was intending to save weight from airframes long step as i need them on both sides. Likely not worth the effort after i give it more thought.
    3,407
    Drilling out holes is the usual way of removing weight from these step angles.
    Nov 2015
    Fairbanks, AK
    41
    Wow, good to know. Take a pretty good hit to bend one, though 61T6 is “soft” enough to deform
    10,519
    Like peanut butter.
    Likes OzAK, Nolan liked this post
    3,407
    That's not fair! Your toys are bigger than ours! lol
    Likes mike mcs repair, skywagon8a, OzAK, Nolan liked this post
    10,519
    That's not mine, but I did have access to one like it. It's amazing what one can do if he has the right tools.
    Likes mike mcs repair, Nolan liked this post
    3,190
    Everyone I know has one of these in their hangar.
    11,370
    everyone i know has one of these in their hangar.
    i wish....
    Mar 2016
    1,515
    Like peanut butter.
    I have use of a 50 ton press brake 2 miles from my shop, it will not bend most alloys and heat treats of Ti without buckling or cracking. This is proven. The material is more complex to work with than most people can fathom.
    Regards, Charlie
    10,519
    Other than using the correct bend radius, how is bending Ti done?
  1. Stock PA-12 gear, stock fuel tank and strut questions
    By txfirefighter628 in forum Cafe Supercub
    Last Post: 06-16-2015, 10:48 AM
  2. Titanium Firewall
    By jimboflying in forum Experimental Cubs
    Last Post: 03-16-2015, 10:06 AM
  3. Titanium Bolts ?
    By Wolf Cub in forum Experimental Cubs
    Last Post: 07-03-2014, 03:04 PM
  4. Titanium fuselage
    Last Post: 12-08-2005, 08:22 PM
