Results 1 to 18 of 18
Thread: Wipaire 2,000 lb fuselage cluster modification
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    761
    Does anyone have a picture of Wipaire’s fuselage cluster modification? Thanks!
    Jan 2008
    Arlington, WA
    761
    Is this little tube all that gets added to the fuselage?
    Steve Pierce pic
    Amy's Avatar
    Jul 2009
    WI/MN/SD
    712
    Steve Pierce pic
    Yup, that’s it! It reinforces the door cluster. Drop me an email at agesch(at)Wipaire.com and I can send you a helpful reference guide that walks you through the 2,000 lbs. kit components and requirements.
    —Amy
    Proud owner of a collection of airplane pieces (sometimes in one big piece) known as the Oklahoma Kid.
    Thanks Charlie Longley thanked for this post
    Grant's Avatar
    At Work.....
    1,803
    Are you starting with a 1750 GW Airplane?
    Jan 2008
    Arlington, WA
    761
    Quote Originally Posted by Grant View Post
    Yes 1962 PA18-150
    Sep 2002
    248
    Folks at wip told me the small tube is not structural
    They said it was only put there so it could be easy to identify if their kit was installed
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    747
    And you get that cool 'One Ton Cub' sticker!!
    Amy's Avatar
    Jul 2009
    WI/MN/SD
    712
    Quote Originally Posted by C-YQK View Post
    I have been trying to figure out where this rumor came from. I’ve asked the team here that worked on the certification and others that have been here 25+ years and they say that is not the case. It is an easy way to see if an airplane has been modified but we are not in the habit of requiring installs of cosmetic items. I went 8 years never hearing this rumor and then three times this year. Would be curious to hear the source and check if their info is different from what I’ve researched.
    —Amy
    Likes A very stick puppy liked this post
    2,180
    I would call that rumor BS. If I remember right the rear strut has a reinforcement at the spar attachment that is pretty easy to see. I will have to look at mine to be sure I am getting old and only keep so many penguins on the iceberg.
    nd
    3,666
    amy, werent some of the 2000lb ers on floats breaking or cracking the door frame where that brace is?
    3,234
    Quote Originally Posted by Bearhawk Builder View Post
    Who can post a pic of that barbell-pumping Cub?
    Tried to find one online a while back but couldn't.
    3,234
    Found one!
Name:	one ton cub.jpg
    Amy's Avatar
    Jul 2009
    WI/MN/SD
    712
    I have not heard of that, but I also am not really involved in the tech support side, so I wouldn’t necessarily know if that had been reported to us. There are more knowledgeable folks than me that handle warranties, tech support, etc. which is a good thing. I’ll ask around though, would be interesting to know. Like everything in life, if you try hard enough you can break anything!
    —Amy
    20,190
    Likes Hardtailjohn, Charlie Longley liked this post
    2,180
    Thanks Steve! looks like that penguin was still alive and kicking.
    Jan 2008
    Arlington, WA
    761
    Steve what were these spars and ribs painted with?
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    790
    A few years ago I was able to discuss this with Jim Richmond of Cub Crafters, and found that he had some first hand knowledge of the testing.
    He as I recall said that a used older fuselage (pre 4130) was used for the drop testing and that there must have been some sort of flexing in this area. Perhaps similar to leaving your rear seat cross over bar out, and have a rough landing. The installation of the tube stopped it and satisfied the Feds.
    They wanted the gross weight upgrade to apply to as many cubs as possible; so I guess you test the “weakest link”.
    Jim said that he used a new 4130 fuselage for their GW increase testing and this issue didn’t come up.
    Ed
    Likes DENNY, Amy, jrussl, Charlie Longley liked this post
    20,190
    That was Polyfiber white epoxy primer.
  1. Fuselage Cabane Attach Point - Modification
    By Grant in forum Modifications
    Last Post: 07-21-2020, 10:55 AM
  2. Experimental Fuselage Modification
    By Olibuilt in forum Experimental Cubs
    Last Post: 12-14-2011, 03:04 PM
  3. Fuselage modification
    By Dbow in forum Cafe Supercub
    Last Post: 03-20-2010, 07:57 PM
  4. cluster flys
    By scout88305 in forum Cafe Supercub
    Last Post: 09-22-2006, 04:21 AM
