Results 1 to 7 of 7
Thread: Float fittings/ stainless control cables
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    761
    My welder said itís pretty easy for him to weld on Atlee float fittings. I am going to go ahead and do it on my Super Cub project. Should I also put in stainless control cables? I am changing them anyway. I vaguely remember there being some issue with stainless longevity. Is there anything else to consider float wise for a rebuild.
    11,514
    Quote Originally Posted by Charlie Longley View Post
    stainless cables will fray much sooner than galvanized.... so unless you WILL BE ON FLOATS/salt water.. go with GALVaNIZED...
    Jan 2008
    Arlington, WA
    761
    That’s what I remember now. I have no plans to put it on floats. But I might get the bug plus there’s resale value to consider.
    10,658
    Soak your galvanized cables in a juicy mix of paralketone. Let it penetrate thoroughly. The cables will then last as long as stainless in a seaplane environment.
    https://www.aircraftspruce.com/catal...aralketone.php
    Thanks Charlie Longley thanked for this post
    cruiser's Avatar
    South Glens Falls, NY
    1,481
    Originally from John Schwaner at Sacramento Sky Ranch https://www.askbob.aero/content/airc...d-carbon-steel
    Feb 2006
    Maine
    777
    Weld the second tail handle on.
    Sep 2004
    Illinois & Wisconsin
    742
    And the pulley brackets for the water rudder control cables.
  1. Carb Control Cables
    By C-YQK in forum Experimental Cubs
    Last Post: 04-23-2012, 10:04 AM
  2. Control Cables?
    By gdafoe in forum Experimental Cubs
    Last Post: 03-09-2008, 12:40 AM
  3. Control Cables Stainless vs Galvanised
    By Steve Pierce in forum Tips and Tricks
    Last Post: 11-03-2003, 05:44 PM
